Old 11-02-2019, 05:34 PM   #1
dubjunkie74
dubjunkie74 is on a distinguished road
Default Saturn Vue - Code C0460
Hey. Thanks for adding me on.
I have a 2008 Saturn Vue with 100,000 KMS. 2.4l XE
I have cleared codes and go for a drive. Sounds like the traction control cycles hard and then both the lights for traction or stabiltrak go off.
The Code says C0460 5A Steering angle sensor plausibility.....
My live readings while drive show my wheels sensors reading same MPH so no differences or spikes.
My resistance at the wheel senors are : LF 6.68 M LR 7.1 M RF 4.3M RR 4.5M
I have tried a recalibration of steering angle as well.
On a separate (or related) note I am getting a code for battery at the BCM although my V at the battery (brand new) while running is 14.5
Also a passenger Airbag.
Any ideas?
Thank you for any direction you can give. I am using a Snap On Modis Edge for scanning.
dubjunkie74 is offline   Reply With Quote
Old 03-31-2020, 05:14 AM   #2
kajakid
kajakid is on a distinguished road
Default Re: Saturn Vue - Code C0460
We're sorry to learn about the troubles you're having with your Vue. Is the specialist you're working with one of our GM professionals? Assuming this is the case, we're glad to catch up on this with you!
kajakid is offline   Reply With Quote
Old 04-01-2020, 05:18 PM   #3
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
The code is not related to wheel speed sensors.
In this link there is a pic that shows the steering angle position sensor location, below the steering wheel in the column.
Before considering replacement, check the wiring and clean and replug the electrical connector and recalibrate. You can most likely read the raw data from the sensor on your scantool.
https://www.justanswer.com/saturn/82...nsor-code.html
code 702 on 01 saturn sl2 rednose38 S-Series General 1 09-24-2012 08:18 PM
97 saturn sl2 code 341 HELP woonyboi02895 S-Series General 11 06-25-2012 10:18 PM
a lil help please, 93 saturn sl2... code 43 Silent S-Series Tech 13 06-01-2009 03:46 PM
code 26 saturn sl1 94 softspot S-Series General 3 02-13-2006 01:57 PM
1994 saturn sl1 code 26. help please softspot S-Series Tech 4 02-11-2006 08:19 PM
