Old 12-15-2019, 05:34 PM   #1
ddemier7
ddemier7 will become famous soon enoughddemier7 will become famous soon enough
ddemier7's Avatar
2004 ION-1 Sedan
Dizzy No heat please help
2004 Saturn Ion sedan
Just replace motor with a new Autozone thermostat and cant get heat. I did notice lower radiator on drivers side hose has a minor leak so I will fix that.
Any ideas how to burp the system to get heat or do you think I got a faulty thermostat?
ddemier7 is offline   Reply With Quote
Old 12-15-2019, 07:09 PM   #2
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
Dizzy Re: No heat please help
Fixed lower radiatir hose leak. Upper hose still gets hot and lower radiator hose cold. It acts like my brand new Duralast thermostat is stuck closed?
Coolant is gurggling in the expanion tank.
Any idea guys? That thermostat is a pain to get to when the engine is in the engine bay. Wow
Old 12-17-2019, 11:47 PM   #3
bern
bern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of light
2004 ION-2 Sedan
Default Re: No heat please help
maybe you have a blown head gasket. pressure test the cooling system with the spark plugs out.
Old 12-18-2019, 07:52 PM   #4
Dsaturn
Dsaturn is just really niceDsaturn is just really niceDsaturn is just really niceDsaturn is just really nice
2001 L-Series 2.2L Sedan
Did you put Tstat in the right direction? Never use Autozone crap Tstats. Use Stant super stats. Yes cost more but an overheat can result in bad headgasket costing 100dreds more for repair.
https://www.infowars.com/ The answer to 1984 is 1776. We are not a Democracy. We are a Constitutional Republic. A Democracy is Two Wolfs and a sheep deciding what is for Lunch!
Dsaturn is online now   Reply With Quote
Old 12-18-2019, 09:41 PM   #5
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
Thumbs Up Re: No heat please help
This motor ran just fine as I drove the car to work many times before removing the engine. It only has 127,000 miles on the motor.
The t-stat can only go in one way on the 2.2 ecotec. Impossible to put t-stat in backwards as the t-stat housing has a 90 degree elbow that won't allow reverse installation of t-stat.
I think im going to replace that Autozone t-stat and just be done with it.
Old 12-22-2019, 03:06 AM   #6
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
You were right I installed thermostat backwards. T-stat goes in first then the black plastic coupler then the t-stat housing. I had it all backwards.
unclog heater core when no heat or very little heat strnlvr S-Series General 63 12-05-2015 09:20 PM
no heat/lack of heat problem mr18436572 S-Series Tech 7 04-16-2015 11:01 PM
no heat t1264rk S-Series Tech 12 11-20-2014 07:20 PM
'04 Vue heat problems (no feet heat) PatrickMcD Vue Tech 5 01-24-2014 05:49 PM
"Heat shield rattle" without a heat shield Modding_out S-Series General 2 01-15-2014 11:58 PM
