Old 03-14-2007, 08:08 AM   #1
Gbody403
Gbody403 is on a distinguished road
1996 SC2
Default Radiator leak - is this common?
Yesterday the low cooland light came on while driving to work in my 96' SC2 so last night I looked for the leak. It's seems to be leaking around around the metal stamping where the top transmission line connects to the radiator. Has anyone else had this problem and is there a fix other than replacing the radiator? My car has about 160K on it.
Gbody403 is offline   Reply With Quote
Old 03-14-2007, 08:23 AM   #2
M.Nguyen
M.Nguyen is on a distinguished road
M.Nguyen's Avatar
1993 SL2
Default Re: Radiator leak - is this common?
there are cracks in the rib on the driver side radiator end tank.
Your only option (other then JB weld it) is to replace the whole radiator. You cannot replace just the plastic end tank.
Has happened in every saturn i've owned (4) and every saturn i've known (probably another 5) within my group of friends.
M.Nguyen is offline   Reply With Quote
Old 03-14-2007, 08:50 AM   #3
DonP
Cracking of the plastic end tank on the driver side below the inlet hose (and above the transmission connection on automatics) is a common problem as cars reach about the 10-year point.
Replacing the radiator is the best fix. Anything else will probably be a temporary fix at best.
Old 03-14-2007, 08:54 AM   #4
Sky King
Sky King is on a distinguished road
Sky King's Avatar
1999 SC2
Fairly common failure. I have replaced 3 radiators in the 4 Saturns I have had. They really aren't hard to replace. I don't advocate using the JB Weld. Some people have reported success but it is going to temporary and you will be changing it anyway sooner or later anyway.
If you do choose to go the JB Weld route, to do it right, you will probably have to take the radiator out anyway. Also I think the people who reported the best results used some form of mesh material with the JB to help reinforce it.
1999 SC-2 280,000 miles -mine now also dead, RIP
1995 SL-2 296,000 miles - my wifes totaled, RIP
1993 Chevrolet S-10 Pick-up - mine
2003 Harley Davidson Low Rider - mine
Sky King is offline   Reply With Quote
Old 03-14-2007, 12:36 PM   #5
Gbody403
1996 SC2
Thanks for confirming my suspicion. Now I have to ask myself if I should buy another used radiator from the junk yard or buy a new one? If 10 years is an accurate service life then it would be silly to buy a replacement from a yard right? If I go new, anybody have a good source (cheap)?? Thanks.
Old 03-14-2007, 02:57 PM   #6
DonP
Ten years appears to be the typical life, your mileage may vary as they say. But given the amount of effort it takes to replace the radiator (not difficult, just time consuming) many folks find it not worth doing more often that necessary if you plan to keep the car for more than a year or two.
If you are going to get rid of the car in a year or so and short on cash it might be worth trying a cheap used unit. Just inspect it very carefully for any signs of cracking.
Check the usual suspects for after market replacements and warranty options. AdvanceAutoParts sold a lifetime warranty unit for about $150USD. OEM from saturnparts.com is more like $260USD.
Old 03-14-2007, 04:05 PM   #7
saturnhouse
saturnhouse will become famous soon enough
FYI, there is a theory (discussed on this board) that frequently checking the coolant, and replacing the coolant cap while the engine is still warm, can contribute to this kind of leak.
The theory is that, if you reseal a hot system at "neutral" air pressure, the system will develop negative pressure when it cools, and then go back to neutral pressure when hot. (As opposed to being at neutral pressure when cool, and then being at positive pressure when hot.) This cycling back and forth to negative pressure "sucks in" and stresses the plastic end tanks in a way that contributes to cracking.
If you have to check the coolant in a hot engine, try to wait till it cools before replacing the cap. If you have to put the cap back on while the system is hot (to drive home), as soon as the engine cools, take the cap off and put it back on again to establish a neutral cool pressure in the system.
With this thought in mind, I'd start with a new radiator vs. getting a used one.
Good luck.
saturnhouse is offline   Reply With Quote
Old 03-14-2007, 04:15 PM   #8
Luke
Luke's Avatar
Fm Saturn House
^ ^ ^ ^ ^ ^ ^ ^ And I check my coolant level only when the engine is stone cold.
Luke is offline   Reply With Quote
Old 03-14-2007, 06:34 PM   #9
trimjb
trimjb is on a distinguished road
trimjb's Avatar
Good info. Saturnhouse. I just replace my radiator. Cracked in the same place as stated on a 95 SL-2 twin. I checked the water level when hot after running and replaced cap. When I get home I will remove and reinstall cap with a cold motor. Will pass along to my son.
Gbody403- replace with a new unit. Your wasting your time on a used unit. Their not that expensive. Hardest part is getting to the 2 bolts that hold the AC coil to the radiator. The complete change out took me about a hour.
trimjb is offline   Reply With Quote
Old 03-14-2007, 07:37 PM   #10
madpogue
1996 SW2
Whatever you choose, start soaking those tranny line connections with PB Blaster NOW, to give it time to work.
Old 03-14-2007, 11:00 PM   #11
Greg1
Greg1 will become famous soon enough
Greg1's Avatar
I see some on Ebay for around $75 shipped. There is even one now for $64 with bidding ending soon.
97 SW2 5-Sp 273k -mine
02 SC2 5-Sp 67k - best friend's
Greg1 is offline   Reply With Quote
Old 03-15-2007, 06:39 AM   #12
bgates2b
bgates2b is on a distinguished road
bgates2b's Avatar
2007 AURA XR
1994 SL2
I would say 90% of the radiator leaks are at that spot. I originally thought it might be due to the tranny cooling lines and the rocking an automatic has with Reverse slam, but it seems to affect cars with manual transmissions just as often, and they don't have lines from their trannies to the radiator.
I replaced my original radiator at 160K 3 years ago. I currently have a coolant leak somewhere as I have to add coolant every two weeks and I can smell it after driving the car. I had a radiator shop replace the last one, but I found a Modine on E-bay that I might use if it is the radiator and I feel like sinking money into a car I might sell.
"Congratulations on your brand new 2007 Acura" - Tenisha, the On*Star rep that handled my call during the Aura's delivery
bgates2b is offline   Reply With Quote
Old 03-15-2007, 10:03 AM   #13
Gbody403
1996 SC2
Thanks for all the great input. I really think that new is the way to go. I'll have to check the e-bay listings that were mentioned.
common AC leak areas to check 425oldsmar S-Series General 4 08-12-2009 09:28 AM
2003 VUE V6 oil leak - common? bxd20 Vue Tech 3 06-02-2009 09:18 PM
Driver side leak & sunroof leak-common? Miss Holly S-Series Tech 3 01-06-2008 02:01 AM
Transmission leak, common places? The Critic S-Series Tech 6 09-21-2006 04:06 AM
common oil leak? BigMac Miscellaneous Tech 6 02-03-2004 09:00 AM
