Old 09-20-2022, 08:45 PM   #1
Rut Dog
Rut Dog is on a distinguished road
Arrow Are 2004 V6 Honda transmissions reliable? Help! I found a 88K and need to act quick
I found an 04 Vue V6 AWD 88K miles (!) with Honda engine and transmission.
Many of those mile have been towed behind an RV.
I would have bought it today if not for the transmission slipping, once and only once. I gunned it while moving about 30 MPH and the RPM shot up to 6K and pulsed. I immediately backed off the pedal and it immediately corrected. Over the next hour I was unable to reproduce this problem.
There are posts on CarComplaints, a website I know nothing about, that talk about the transmission failing in the Honda V6 (not the CVT) due to overheating caused by a faulty valve body.
https://www.carcomplaints.com/Saturn..._failure.shtml
Honda Acura STL HO5 MDKA Superior Transmission Shift Kit Valve Body Update, MDRA transmission
78930B Honda Transmission Lube Correction Kit (6 Cylinder Models) (MDRA & MDPA)
CORRECTION should say it ALL!!!
Honda did transmission recalls in 2004. Saturn Vue 04-07 used Honda Power train on V6 AWD. GM NEVER recalled it and knows little about Honda power train or that they used Honda! Lube valve update is critical! Mine failed on interstate! Lube valves failed to cool transmission and overheated it and torque converter.
2004 Saturn VUE V6 HONDA Engine-Transmission @114,000 miles. Honda had a recall for a transmission defect in 2004 and settled a class action lawsuit in 2006. Saturn never issued a recall. Now I'm facing a $4,000 repair. This is a total disgrace. Called GM and Honda - complete waste of time.
However, there are very few mentions of this problem on SaturnFans.
I've owned my '03 since it was new. For years I've been looking for a low mileage '04-'07 and here it is. Like I said, I'd have bought it already if not for the trans slip.
Rut Dog is offline   Reply With Quote
Old 09-21-2022, 12:19 AM   #2
Rut Dog
Default Re: Are 2004 V6 Honda transmissions reliable? Help! I found a 88K and need to act qui
The one I'm looking at is 2005, not 2004. My mistake.
Those reports at complaints.com are for a 2004.
I started another thread in Vue General:
http://www.saturnfans.com/forums/sho....php?p=2377228
Old 09-30-2022, 05:39 PM   #3
What a VUE
What a VUE is on a distinguished road
What a VUE's Avatar
Single slip, could not reproduce sounds like old/low fluid. Once fluid is up to temp, prevents reproduction.
See about having the trans fluid checked for level and discoloration/burn.
Dave
07 VUE 3.5 AWD
What a VUE is offline   Reply With Quote
What ATF for the VUEs with Honda transmissions? 07VUE Vue Tech 1 09-08-2012 09:41 AM
2004 Vue V-6 or Honda Pilot? vue04 Vue General 7 04-13-2011 05:34 PM
2004 Vue Honda V6 , no start VIP Vue Tech 6 12-13-2009 09:41 PM
2 quick questions on manual transmissions NGFD14 S-Series Tech 6 07-04-2007 08:02 AM
Honda found the torque Plastic Gravity Mods and Performance 43 06-25-2001 08:14 PM
