Old 05-30-2012, 07:18 PM   #1
Loanshark
Loanshark is on a distinguished road
Default 02 sl1 overheating gushing coolant and throwin codes
Ok so my brother gave me his 2002 sl1. It has 207000 miles. Today while sitting at a stoplight I noticed the temp gauge climbing. He warned me that when the gauge reaches the half point it gushes coolant out the cap. So when I got to my destination I popped the hood to see what was up. A few minutes later it started gushing so I shut it down. The gauge read half or just over... Then the SES light came on. P0301 and p0410... Where should I start.
Add to Loanshark's Reputation
Rate the quality of this post and help Loanshark reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Loanshark is offline   Reply With Quote
Old 05-30-2012, 07:22 PM   #2
lil_buddy
lil_buddy is on a distinguished road
1997 SC1
Default Re: 02 sl1 overheating gushing coolant and throwin codes
ECTS
http://www.saturnfans.com/forums/sho....php?t=177672#
Add to lil_buddy's Reputation
Rate the quality of this post and help lil_buddy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lil_buddy is offline   Reply With Quote
Old 05-30-2012, 08:28 PM   #3
magtec
magtec will become famous soon enough
1995 SW2
coolant reservoir cap, the ECTS will not make it gush coolant at the half mark.
Add to magtec's Reputation
Rate the quality of this post and help magtec reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
magtec is offline   Reply With Quote
Old 05-30-2012, 08:50 PM   #4
ShawnV
ShawnV has a spectacular aura aboutShawnV has a spectacular aura aboutShawnV has a spectacular aura about
ShawnV's Avatar
1996 SW2
2000 SW2
+1 This might be an easy fix!
Follow mag's advice and replace the coolant cap. Get one used or at your local auto parts store.
Add to ShawnV's Reputation
Rate the quality of this post and help ShawnV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-30-2012, 09:08 PM   #5
madpogue
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
1996 SW2
It will if it's failed, and the temp is actually a lot higher than it's reporting. But if it's pushed coolant out the cap multiple times, best to replace it anyway.
P0301 is probably an intake manifold gasket failure. Separate problem.
Add to madpogue's Reputation
Old 05-30-2012, 09:11 PM   #6
Loanshark
That would be an easy fix. I forgot to mention, I have not heard the fan kick on unless I turn on the AC. Though I don't know if it is really warm enough to trigger it. Could the reservoir cap really be causing this? Or is this just a place to start?
Old 05-30-2012, 09:26 PM   #7
dbsanfte
dbsanfte is on a distinguished road
1999 SW2
The computer relies on the ECTS signal to tell it when the coolant is hot enough to turn on the fan. If the ECTS is cracked and sending bad data, it never gets that signal and the fan never turns on, even if it's boiling.
Replace the coolant temp sensor and the rad cap, about $20 total, and you should be fine.
Replace the intake manifold gasket too, although that's a separate issue. Also fairly cheap.
Add to dbsanfte's Reputation
Rate the quality of this post and help dbsanfte reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dbsanfte is offline   Reply With Quote
Old 05-30-2012, 10:58 PM   #8
Loanshark
Thanks for the help folks. I will report back soon...
Bye the way I got 36.74 mpg from Detroit to north of Cincinnati (~240 miles) when I brought it home, with no issues.
Old 05-31-2012, 10:35 PM   #9
Loanshark
I changed the ECTS and coolant cap this evening. The temp gauge reads at about 5/16. I didn't want to let it sit and get hot... It is not getting up to the 3/8 while moving. Should I go ahead and do the thermostat? Is the Stant from advance auto ok?
Old 05-31-2012, 10:56 PM   #10
td1238
td1238 will become famous soon enough
5/16 does sound low. Stick a meat thermometer in the reservoir after the temperature has stabilized for at least 15 minutes of driving, preferably at high speed. It should read over 190. If it doesn't, then the thermostat is likely leaking. The stat tends to also be bad when the other two go bad.
Be careful not to burn yourself.
Add to td1238's Reputation
Rate the quality of this post and help td1238 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
td1238 is offline   Reply With Quote
Old 06-01-2012, 08:44 PM   #11
Loanshark
Coolant was 175 degrees so I did the thermostat tonight... The gauge now rides at 3/8. New issue, the low coolant light is on. Can I poke the float to try and free it up? Where is it?
Old 06-02-2012, 08:46 AM   #12
alordofchaos is a jewel in the roughalordofchaos is a jewel in the roughalordofchaos is a jewel in the rough
1997 SC2
It's in the reservoir tank, where you add the coolant. Sometimes it just needs a little shake, other times, you need to take the tank off and rinse out thoroughly.
First, make sure it is really full. The coolant should be up to the plastic dividers you see inside the tank.
Being used to "overflow tanks" from way back when, first time I filled up my car, I only filled it about halfway up the side of the tank
...Wait, what, I actually won that eBay auction?
Guess I now (12/2008) own a 1998 SL2, silver 5 spd :p
And now (7/2010), a Craigslist 1997 SC2 5 spd
Old 06-02-2012, 10:01 AM   #13
Loanshark
It fixed itself... Thanks for all the help. This is a great forum!
Old 06-02-2012, 11:12 AM   #14
madpogue
1996 SW2
"Things don't fix themselves...." (sorry, couldn't help it.....)
Old 06-02-2012, 01:58 PM   #15
Loanshark
Lol, let me rephrase then. The light went out, I will mess with it the next time I need to drain the coolant.
Old 06-02-2012, 02:07 PM   #16
madpogue
1996 SW2
The float probably just got unstuck. The Brazil reference was a joke....
Old 06-02-2012, 05:52 PM   #17
Loanshark
Oh yeah, I know. I've never seen that, was it good?
Old 06-02-2012, 07:18 PM   #18
madpogue
1996 SW2
One of the best, most bizarre movies of all time. If you're into dark comedy with a healthy dose of social commentary on modern times, get it and be prepared to watch it several times.
Throwin Codes Silverl300 L-Series Tech 0 07-29-2011 12:08 AM
Overheating, oil in coolant res GlennCoco S-Series General 26 11-10-2009 08:41 AM
Coolant overheating and other problems strawberripocky S-Series General 13 08-26-2009 04:07 PM
Coolant Overheating...help, I'm at Wits END! myjohnsonsmagic S-Series General 17 02-06-2006 02:40 PM
Just throwin' this out there: Fendi Watch homieg9999 Old Classifieds 0 06-13-2005 09:34 AM
