Old 02-08-2010, 08:22 AM   #1
paulo
paulo will become famous soon enoughpaulo will become famous soon enough
Default error codes
I have a 2003 Ion with 95,000 miles. CEL light on and pulled 4 error codes. The last two I was able to erase, but the first two I could not erase.
P0031 /Poo37 last two are P0135/ P0141. What do these codes mean and why am I unable to erase the first two codes? How can I erase them?
Add to paulo's Reputation
Rate the quality of this post and help paulo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
paulo is offline   Reply With Quote
Old 02-08-2010, 10:09 AM   #2
Default Re: error codes
P0031....HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
P0037....HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
P0135....O2 Sensor Heater Circuit (Bank 1 Sensor 1)
P0141....O2 Sensor Heater Circuit (Bank 1 Sensor 2)
All related to O2 sensors. Check wiring to both sensors and the fuse(s). Does the engine run OK?
Old 02-08-2010, 10:09 AM   #3
2006 ion2
2007 ION-2 Sedan
www.google.com for the meanings, you can erase them all you want, if there is a problem, it just puts them right back into memory.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 02-08-2010, 11:43 AM   #4
paulo
The engine runs fine. No noticable problems. Does this car have the fiber tip CTS (coolant temperature sensor)? It seems unlikely that both O2 sensors would go bad together. Is there a fuse that runs both O2 sensors?
Old 02-08-2010, 11:59 AM   #5
2006 ion2
2007 ION-2 Sedan
the cts is an s series problem, not ions
2007 Saturn Ion 2
Old 02-08-2010, 12:00 PM   #6
paulo
Are there specific fuses that run the O2 sensors? and could that be the reason why two of the error codes won't reset?
Old 02-08-2010, 01:37 PM   #7
2006 ion2
2007 ION-2 Sedan
I don't know that they would be fused. they send off a really small signal as far as I know.
2007 Saturn Ion 2
99 SC1 Error Codes jpleech S-Series Tech 3 01-09-2009 11:27 PM
Error codes on 94 SL2 kindashort S-Series Tech 25 03-07-2007 12:40 AM
92 SL2 Error codes 26, 32, 45 paxman356 S-Series Tech 15 11-15-2005 10:25 AM
Error codes paxman356 S-Series General 3 10-22-2005 11:49 AM
Error Codes Jay Grove Miscellaneous Tech 2 04-11-2002 10:49 PM
