Old 02-03-2023, 07:24 PM   #1
nealt
nealt is a jewel in the roughnealt is a jewel in the roughnealt is a jewel in the rough
nealt's Avatar
Default 2001 SOHC Chocolate Oil No Coolant Loss
My son's 2001 SC1 SOHC has chocolate'ly oil. His oil level is a little too high, we probably topped it off too much. No coolant loss, no oil in coolant, no oil scum floating on top of coolant, and coolant looks clean as a whistle. He is a frequent short trip driver, 7 minutes. Is this a symptom of just short cold trip winter driving with moisture building up and possible over filling, or is there a more nefarious cause. Haven't noticed this till this winter, has had the car 2 years.
nealt is offline   Reply With Quote
Old 02-05-2023, 05:09 PM   #2
onlinebilerv2.0
onlinebilerv2.0 will become famous soon enough
Default Re: 2001 SOHC Chocolate Oil No Coolant Loss
What is the coolant temp gauge reading?
The coolant temp gauges on Saturns are fantastically reliable. If it shows less than a couple needle widths above the first quarter marking - when warmed up - you likely have a faulty thermostat - making it run cold.
onlinebilerv2.0 is offline   Reply With Quote
Old 02-07-2023, 12:05 AM   #3
uccoskun
uccoskun is on a distinguished road
I have milky oil residue on the oil cap only, I think it is condensation.
If the whole oil is milky, i suspect you have a coolant leak. It means tons of condensation which should not happen on a regular use.
Do you live in a high humidity region?
uccoskun is offline   Reply With Quote
Old 02-07-2023, 05:57 PM   #4
dummo
dummo's Avatar
1997 SW2
I think the short 7 minute trips should be the first suspect.
Change the oil and take it for a long weekend drive and then change the oil again. Oil is a cheap flush agent, especially cheap oil.
• 1997 SW2 used 12/29/2011 with 124,200 -27 mpg
• 2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
• 1994 SL1 new traded
• 1992 SL2 new traded for above
Coolant Loss 2001 Saturn SL2 vikasevan S-Series Tech 8 04-07-2015 02:39 AM
Coolant Leak with other issues! Sohc 2001 please help! aaronhanselman S-Series Tech 6 10-20-2014 05:40 PM
'91 SL1 SOHC Chugging, Hissing and Coolant Loss Mandun S-Series Tech 2 10-03-2014 05:56 PM
94 sc1 sohc oil in coolant bottle, no coolant in crankcase? cracked head? gman41 S-Series Tech 40 10-16-2011 11:04 PM
1997 SC1 Chocolate Milk coolant after a head gasket swap. redquestron S-Series Tech 14 07-04-2009 08:17 PM
