Old 01-27-2023, 09:34 PM   #1
thingsman
thingsman is on a distinguished road
Dizzy new SL@ motor
Looking for a good motor twin cam motor hiding in storage. Have kept up with reg maint and hate to junk it after 292k.
thingsman is offline   Reply With Quote
Old 01-28-2023, 05:45 PM   #2
onlinebilerv2.0
onlinebilerv2.0 will become famous soon enough
Default Re: new SL@ motor
What year?
onlinebilerv2.0 is offline   Reply With Quote
Old 01-29-2023, 09:51 PM   #3
thingsman
Any motor 95-02 would work. The fuel rail & injectors have to be carried over and other minor swaps perhaps like the knock sensor. My SL2 is a 98 automatic.
Old 01-29-2023, 10:47 PM   #4
onlinebilerv2.0
The heads are not the same after 2000. The exhaust and intake manifolds are different.
Where are you located?
Old 01-29-2023, 11:24 PM   #5
The fuel rail also changes in '98 from the return style in '97 with a $5 fuel filter option to returnless with a $50+ filter in '98. Not sure if the rails will swap '96-'99, but whatever years I tried had the mounting boss's in different locations on the intake (only had '93-97's).
Just something to check while the engines are out of the car, easier to swap the IM while it's out if it's required (and could probably have it walnut blasted to clean the carbon/oil out).
Old 01-30-2023, 11:10 AM   #6
TvSteve
TvSteve is on a distinguished road
TvSteve's Avatar
1999 SW2
In mid 1998 the production was changed. Head, manifolds are different.
TvSteve is offline   Reply With Quote
Old 01-30-2023, 07:12 PM   #7
thingsman
Appreciate the responses! The heads are different in later years but it does not matter, what is important is to use the original fuel rail/injectors. The exhaust manifold on my 98 will bolt on to any of the blocks. I did this with my 97 SOHC and swapped in a 02 SOHC.
Old 01-30-2023, 08:16 PM   #8
thingsman
Like to add I'm in Ohio and travel to Florida for possible pick up.
Old 01-31-2023, 01:39 AM   #9
The DOHC heads change in '99. They still use the '91-'98 style intake manifold flange but use the '00-'02 style exhaust manifold flange.
Old 01-31-2023, 11:36 PM   #10
onlinebilerv2.0
The plastic and aluminum intake manifolds can be interchanged??
Old 02-01-2023, 12:09 AM   #11
Waiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to beholdWaiex191 is a splendid one to behold
My '99 has an aluminum intake.
Old 02-01-2023, 09:00 AM   #12
trottida
trottida's Avatar
According to parts listings the aluminum intake is compatible from 1995 through 1999. The plastic intake 2000 through 2002. Not sure what the difference is that would make it incompatible.
https://www.wholesalegmpartsonline.c.../21006844.html
https://www.wholesalegmpartsonline.c.../21008443.html
1999 SL2 MT (311,300 km @ 01/2023)
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 02-07-2023, 12:31 AM   #13
uccoskun
uccoskun is on a distinguished road
Why not getting it from a junk yard?
uccoskun is offline   Reply With Quote
wiper motor compatibility? 2002 sl2 motor in 97 sl2? vikasevan S-Series Tech 2 04-04-2015 03:06 AM
1998 sl2 1.9 motor slight vibration at idle only 32000 on motor any ideas other than Robertssaturn L-Series Tech 1 05-31-2010 08:15 PM
Compression test Warm motor vs cold motor Frankd1 S-Series Tech 2 10-14-2008 04:47 PM
saturn motor sports monster motor block? wastedatmu S-Series Mods 7 02-06-2007 11:18 AM
HVAC Blower Motor Dying...can one fix motor? flyhop S-Series Tech 2 09-28-2006 10:08 PM
