Old 01-24-2023, 02:34 PM   #1
01SC94SL
01SC94SL is on a distinguished road
01SC94SL's Avatar
2001 SC1
1994 SL1
Default Odometer Total Change
I have an 01 SC1. It has 312k + miles on it and that's what the odometer showed until recently. My son borrowed the car for a few days and brought it back but now the odometer shows something like 66k miles? It still goes up as you drive but at a rate around maybe 1/2 or less of what it should. He didn't do anything he knows of or even really noticed. The speedometer still seems right and it still runs good so it's just really annoying as I track every mile, fill-up and repair and now that's all thrown off. Anyone ever experienced anything like this or hear of this happening and know a way to fix it?
94 SL1
01 SC1
08 Aura
01SC94SL is offline   Reply With Quote
Old 01-24-2023, 11:16 PM   #2
onlinebilerv2.0
onlinebilerv2.0 will become famous soon enough
Default Re: Odometer Total Change
Ever see the Stephen King movie Christine???
My advice - be very nice to the car - and don' t walk in front of it......
onlinebilerv2.0 is offline   Reply With Quote
Old 01-26-2023, 12:42 PM   #3
As the '00-'02 odometer reading is generated inside the BCM I'd assume the fix is replacing the BCM.
Old 01-26-2023, 01:27 PM   #4
01SC94SL
01SC94SL's Avatar
2001 SC1
1994 SL1
Is there any way to check if it is the BCM before I shell out $100+ on another one?
94 SL1
01 SC1
08 Aura
Old 01-27-2023, 11:18 AM   #5
trottida
trottida's Avatar
Is your son's name Ferris by chance? Ferris Bueller....
1999 SL2 MT (311,300 km @ 01/2023)
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 02-02-2023, 01:07 PM   #6
TomM96
First thought ... maybe reversed leads 'jump' starting... or excessive road salt
on highway in blizzard.
But, I recall OldNuc seemed to have a lot of experience with odometers.
He removed the large plastic instrument cluster bezel, and got to repair components.
He advised replacing gen2 IPs with gen3, specifically because the gen2
odometers would eventually fail due to lost lubrication on the mechanical gear-drive.
Without the mechanical gear drive, i guess whatever sensor is involved might
be suspect. So, I might try a new cluster from a boneyard, before adopting
what is likely the superior advice offered by Fetch (BCM); BUT find out what
the sensor is which provides the info.
Disconnecting/reconnecting the battery Might reset things. Maybe also phone the Service dept at a Chevy dealer to see if that is a routine issue -- that
might be fixed with a TechII.
I bought a useless cluster from one junkyard for $100, and elsewhere got
2 good ones for $25- each.
Old 02-07-2023, 12:29 AM   #7
uccoskun
uccoskun is on a distinguished road
I saw some speedometers use EEPROM chips to store millage. In my SL1, if you change the cluster, it still remembers the original millage. So I think something happened to your EEPROM chip so it remembers the wrong millage. I do not think you can recover it easily other than removing it and overwriting it.
Here is an example youtube video.
https://www.youtube.com/watch?v=vHxv...l=Autoelectrix
uccoskun is offline   Reply With Quote
99 PCM Change and Odometer Reading? Spaghettiohead S-Series Tech 6 11-03-2013 11:20 PM
68 total US Astra sales in November (and updated total sales number) emg77 Astra General 2 12-10-2009 01:17 AM
Can you change the color of your odometer read out? aheroawakend Ion Mods 4 06-07-2008 11:02 PM
Can I change my odometer reading? batmobile L-Series Tech 8 04-24-2008 03:32 PM
'99 SL2 odometer bulb change. How to do it? ken b. S-Series General 2 07-15-2006 03:41 PM
