Old 04-02-2006, 10:34 PM   #1
etmorrison
etmorrison is on a distinguished road
1992 SL1
Default SL1 SOHC - Run away engine - Help!
My PCM gave me a 32 code so I cleaned the EGR valve. On assembly the engine raced wildly. So I cheched all vaccum hoses and replaced the suspect ones. Still races wildly?? Seems like aI have a vacuum leak somewhere but can't locate it. Its doing the same thing that happened when I knocked off the brake vaccum booster hose from the back of the intake manifold, but I checked and its in the hole solid. Any Ideas would halp at this point as I spent 5 hours on it today to no avail. H E L P !
Add to etmorrison's Reputation
Rate the quality of this post and help etmorrison reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
etmorrison is offline   Reply With Quote
Old 04-02-2006, 10:39 PM   #2
andy_95sl2
andy_95sl2 is on a distinguished road
andy_95sl2's Avatar
Default Re: SL1 SOHC - Run away engine - Help!
racing wildely... does this mean that it revs until the PCM enables the rev limiter at 4k rpms?? racing wildely doesnt point to a vacuum leak, normally a vacuum leak makes the engine idle a little high, like 1.5k or 2. If you cleaned the EGR it shouldnt really race.. check all the connections. Do you have any codes being generated after this? maybe the throttle cable got hung up being that it is a SOHC and the egr is on the intake manifold.
2004 Jeep Wrangler Rubicon -> daily & toy =)
2009 BMW 128i -> sold
2003 VW GTI 1.8T -> wrecked
1998 Saturn SL2 -> parted out
1995 Saturn SL2 -> sold
Add to andy_95sl2's Reputation
Rate the quality of this post and help andy_95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
andy_95sl2 is offline   Reply With Quote
Old 04-02-2006, 11:48 PM   #3
scsomike
scsomike is on a distinguished road
nothing holding the throttle open around the cable or linkage is there?
'97 SL2, 5spd get around car.
Add to scsomike's Reputation
Rate the quality of this post and help scsomike reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
scsomike is offline   Reply With Quote
Old 04-03-2006, 12:12 AM   #4
cindy_and_lee
cindy_and_lee is on a distinguished road
cindy_and_lee's Avatar
1995 SC1
Check the PCV valve going into the valve cover, make sure the hose isn't brittle and cracked. With the hose going to the intake to the PCV, you will never see it, it will make it idle at about 2500-3000 rpm. Check that, and make surethere isn't any vacuum leaks around the PCV.
Add to cindy_and_lee's Reputation
Rate the quality of this post and help cindy_and_lee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cindy_and_lee is offline   Reply With Quote
Old 04-03-2006, 06:47 AM   #5
mohave
mohave is on a distinguished road
mohave's Avatar
My 95 SL1 did almost the same thing with a very high idle. It turned out to be the oxygen sensor.
Add to mohave's Reputation
Rate the quality of this post and help mohave reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mohave is offline   Reply With Quote
Old 04-09-2006, 07:18 AM   #6
etmorrison
1992 SL1
Thanks it was the cable ajar due to my remoring the EGR vale to clean it , still getting the 32 code going after the O2 sensor now
- Thanks for the wake up call on the throtle cable
Old 04-09-2006, 06:42 PM   #7
Katie
Katie is on a distinguished road
1993 SL2
Did you double check the EGR diaphram when you had it out? (e.g. depress pintle, block vacuum hole with finger and see if it holds)
You could also check the ohms across the egr solenoid and make sure it is still good.
Add to Katie's Reputation
Rate the quality of this post and help Katie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Katie is offline   Reply With Quote
95 SOHC engine into a 96 SL1 casterman S-Series Tech 3 04-13-2008 12:07 PM
1996 SL1 SOHC may need new engine casterman S-Series Tech 3 07-12-2007 07:17 AM
has any1 thrown a timing chain and NOT had engine damage on SOHC sl1 type engine? MacExperts S-Series Tech 14 09-21-2006 05:04 PM
Engine swap 97 sl1 sohc Martino sl 97 S-Series Tech 0 09-14-2005 05:00 PM
WTB: SOHC Engine for '95 SL1 ybstuk Classifieds 2 07-09-2003 03:55 PM
