Old 12-02-2002, 07:50 PM   #1
Bigsmoker
Bigsmoker is on a distinguished road
Default Washer ports
On my 2000 SC2 the washer holes seem to keep freezing up on me. I have to get out of the car and blow air into the holes. I never had a freezing problem on my 94 SL1 . What can be done to prevent freezing up?
Add to Bigsmoker's Reputation
Rate the quality of this post and help Bigsmoker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bigsmoker is offline
Old 12-02-2002, 08:32 PM   #2
Default
They may be freezing but more likely they are clogging up. You have to make sure that when you blow the nozzles out that you don't blow the clog into the other side that and make sure that you are blowing the debris out of the lines by disconnecting them at the firewall.
Add to ssicarman's Reputation
ssicarman is offline
Old 12-02-2002, 10:03 PM   #3
wolfman
wolfman's Avatar
Default
I have seen the nozzles clog on numerous "S" series cars due to crud pumped out of the washer fluid tank. Sometimes the "cheap" blue washer fluid is of less than steller quality. (I think there was a TSB at one point where we put in smaller pump screens). The permanent cure...place a lawnmower style fuel filter in line between the washer pump and the nozzle "T"...they'll never clog up (internally) again.
Add to wolfman's Reputation
wolfman is offline
Intake Ports On Engine Block krazyking01 S-Series Mods 2 04-10-2006 03:22 PM
Aux ports on the '04 Ion 6 CD changer radios? synthkat Ion Tech 7 04-03-2006 08:50 AM
Spark Plug Change--Washer or No Washer? snakeeye S-Series Tech 6 03-12-2006 07:34 PM
Additional power ports KJB Vue General 19 09-03-2004 07:16 PM
intake/throttlebody/manifold/ports toeachitsown Mods and Performance 2 05-16-2002 02:16 PM
