Old 04-09-2006, 12:03 PM   #1
dkimmons
dkimmons is on a distinguished road
Default Car pulls right on accel & left On decel
I am looking at a 96 SC 2 5SP with 103K to purchase. Body is very good but seems to have a front end problem. The steeering pulls to the right when you accel and then back to the left when you decel. I think this may be broken or weak motor mounts but could it be something more serious?
Thans dkimmons
Add to dkimmons's Reputation
Rate the quality of this post and help dkimmons reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dkimmons is offline   Reply With Quote
Old 04-09-2006, 01:35 PM   #2
eljefino
eljefino's Avatar
1995 SW1
2000 SL1
Default Re: Car pulls right on accel & left On decel
it sure could be a front end problem. These cars have equal length half shafts so there's no torque steer from the factory.
Jack up each front wheel and wiggle.
Off the top of my head, a tie rod end is most likely. Not terribly expensive but make the seller fix it so you're sure it's good.
A bad motor mount, you'll feel the motor bounce around when you let off the clutch, but the axles have enough in-and-out splined movement to absorb this by the hubs and the wheels should stay put.
Add to eljefino's Reputation
Rate the quality of this post and help eljefino reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
eljefino is offline   Reply With Quote
Old 04-09-2006, 06:36 PM   #3
Katie
Katie is on a distinguished road
1993 SL2
My guess is also steering knuckle or alignment issues. Although I have never seen this or heard of it, could a bad differential do something like this?
Add to Katie's Reputation
Rate the quality of this post and help Katie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Katie is offline   Reply With Quote
Old 04-09-2006, 08:14 PM   #4
jeep4523
jeep4523 is on a distinguished road
1994 SL2
Sounds like a tie rod issue.
And the axle lengths do differ by a lot, you're forgetting about the intermediate shaft ;-)
Democracy is two wolves and a sheep voting on what to have for dinner. Liberty is a well armed sheep contesting that decision.
Add to jeep4523's Reputation
Rate the quality of this post and help jeep4523 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jeep4523 is offline   Reply With Quote
Old 04-09-2006, 08:45 PM   #5
between5and7
between5and7 is on a distinguished road
between5and7's Avatar
1993 SW1
Wrench Re: Car pulls right on accel & left On decel
Once I forgot to tighten my left side lower control arm and that is exactly what happened. (The bolt that goes thru the sub-frame.) I re-checked my work and found my mistake and all was well.
Good luck.
Add to between5and7's Reputation
Rate the quality of this post and help between5and7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
between5and7 is offline   Reply With Quote
Old 04-10-2006, 11:18 AM   #6
madpogue
1996 SW2
Which, as a function of its mounting, eliminates the torque steer.
Re. the right pull, dunno if this would apply to the S-car suspension, but on a couple old Omni/Horizons I've owned/worked on, a loose or bent control arm, or worn control arm bushings will cause torque steer.
Add to madpogue's Reputation
Old 04-14-2006, 10:15 PM   #7
dkimmons
Thanks to all who got back to me. I checked the outer tie rods and ball joints and they were really bad. Replaced them, had the alignment done and car is driving great. Oh I did purchase it.
Thanks again
dkimmons
Old 04-15-2006, 05:46 AM   #8
jeep4523
1994 SL2
Then you've never mashed one that's boosted or has juice, they DEFINATELY have torque steer. The reason for that is because the OVERALL LENGTH from the trans to the hub is what matters. The intermediate and the passenger side both twist a bit AS A UNIT, which is what causes torque steer. The driver's side also twists, but it can't exert the same forces as the passenger side setup does.
Check out the axle set up on an SRT4, THAT is equal length half shafts ;-)
Old 04-15-2006, 09:56 AM   #9
JADEDSL2
JADEDSL2 will become famous soon enough
JADEDSL2's Avatar
Location: Sullivan, Missouri, USA, North America, Northern West Hemisphere, Earth, Solar System, Left Galactic Arm, Milky Way Galaxy, Local Galactic Cluster, Universe
1993 SL2
1991 SL2
Thans dkimmons
I had the exact same issue with my 91 SL2 5spd when I bought it. It was simply an alignment problem. But I can see it being loose or bad tie rods/ball joints.
"1G8ZJ5472MZ134321"-my Jaded, I will never forget.
"1G8ZF5594PZ249184"-Trinity, for three are now one.
Add to JADEDSL2's Reputation
Rate the quality of this post and help JADEDSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JADEDSL2 is offline   Reply With Quote
Car pulls to the left. Is it the upper engine mount? saturnphreak S-Series Tech 5 08-05-2006 10:52 PM
My RedLine pulls to the left, Help! hbko181 Ion Red Line 21 07-26-2005 12:57 PM
strange knock on accel & decel sps SOHC S-Series Tech 7 11-29-2004 12:16 PM
Pulls to left? TheSaturnKid Miscellaneous Tech 9 03-03-2004 01:16 AM
rythmic metalic squealing on left-hand turns on accel; tire noise on normal left turn rtfm17 S-Series Tech 4 08-25-2003 08:37 AM
