Old 02-05-2012, 08:49 AM   #1
joshuabornemann
joshuabornemann is on a distinguished road
1996 SL2
Default two ects ports which one should i use.
so i have been posting question about my engine swap project here for a couple of days and have one final question. long story short. older engine into a newer car. 1993 into a 1996. The 1993 engine has two temp sensors on the drivers side of the block. I know that the 1996 car only uses one and and it combines both temp sensor and temp gauge. my question is does it matter which hole i use and which one i should leave plugged. i bought a new ects that is the new style combo. just wondering where to put it. top hole or bottom. does it make a difference. thanks
Add to joshuabornemann's Reputation
Rate the quality of this post and help joshuabornemann reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
joshuabornemann is offline   Reply With Quote
Old 02-05-2012, 09:15 AM   #2
Default Re: two ects ports which one should i use.
The lowest one.
Old 02-05-2012, 03:55 PM   #3
Canyon
Canyon has a spectacular aura aboutCanyon has a spectacular aura about
1999 SL1
If you end up with the extra hole plug it up with an old ECTS.
Add to Canyon's Reputation
Rate the quality of this post and help Canyon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Canyon is offline   Reply With Quote
Old 02-06-2012, 10:05 AM   #4
I put brass 2-wire ECTS's in both locations, currently the connector is on the top one. At some point I'll put it on the lower one again, but I don't expect to see a change as they're so close together. I don't know if the way the water is piped through the head put's them farther apart then they look.
Old 02-07-2012, 06:36 PM   #5
joshuabornemann
1996 SL2
yeah i think i will just go buy another ects from autozone and put it in the bottom spot. car currently seems to run fine but maybe it will be even better. i will run this tank of gas out and then make the change and see if i notice a difference in running or gas mileage.
AC valve cores and ports ? ? ? PB in Clt S-Series Tech 13 09-18-2010 09:11 PM
EGR ports cleaning SBXLI93 S-Series Tech 7 01-18-2010 05:23 PM
Aux ports on the '04 Ion 6 CD changer radios? synthkat Ion Tech 7 04-03-2006 09:50 AM
Additional power ports KJB Vue General 19 09-03-2004 08:16 PM
Washer ports Bigsmoker S-Series Tech 2 12-02-2002 11:03 PM
