Old 09-24-2010, 12:19 PM   #1
destro5
destro5 has a spectacular aura aboutdestro5 has a spectacular aura aboutdestro5 has a spectacular aura about
2002 L-Series 2.2L Wagon
2006 SKY
Default Starter replacement, best aftermarket brand?
Looking to replace my 95 Saturn SW2's starter.
Is there any brands I should avoid or choose one over the other?
Can you go re-manufactured or is new the way to go on these?
There recently was a thread discussing aftermarket parts and ones to use/specs/etc. Any idea where that thread is?
Edit: Found that one, http://www.saturnfans.com/forums/sho...ht=spark+plugs
Add to destro5's Reputation
Rate the quality of this post and help destro5 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
destro5 is offline   Reply With Quote
Old 09-24-2010, 01:48 PM   #2
VUEmaniac
VUEmaniac is a jewel in the roughVUEmaniac is a jewel in the roughVUEmaniac is a jewel in the roughVUEmaniac is a jewel in the rough
1997 SC2
Default Re: Starter replacement, best aftermarket brand?
Not sure if they're "the best," but I'm pretty happy with my replacement starter. It's a Bosch unit.
All governments suffer a recurring problem: Power attracts pathological personalities. It is not that power corrupts, but that it is magnetic to the corruptible. -Frank Herbert-
Add to VUEmaniac's Reputation
Rate the quality of this post and help VUEmaniac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VUEmaniac is offline   Reply With Quote
Old 09-24-2010, 04:04 PM   #3
hholbein
1997 SW2
I've had excellent luck with DB-Electrical in TN. Very prompt service, and the unit I have in there now was either new or so thoroughly rebuilt of an OEM Valeo unit as to be new.
http://www.dbelectrical.com/c-1397-19-liter.aspx
1 year no-quibble warranty. $41, + a few shipping option $12 and up. Hard to beat that. Heck the local U-pull-it-and-get-filthy junkyard wanted $20.
Add to hholbein's Reputation
Old 09-24-2010, 11:49 PM   #4
This would be my recommendation also.
Old 09-25-2010, 05:37 PM   #5
SRGW
SRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of light
1997 SL1
Thumbs Up Re: Starter replacement, best aftermarket brand?
+1
I recently replaced mine from DB A OK!!
1995 SL1 174,200 and go'in strong!!
CHECK YOUR OIL!!!
Add to SRGW's Reputation
Rate the quality of this post and help SRGW reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-25-2010, 06:29 PM   #6
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
That db electrical place sounds like they have some pretty good deals. Unfortunately, alternators and starters usually fail quite suddenly. As a result I'll probably end up paying a lot more from my FLAPS, because I'd need to get the work done ASAP and wouldn't be able to go up to a week without my car while I wait for my part to arrive.
To answer the OP's question, AC Delco is the only brand that stands out to me though. The catch is that AC Delco parts are somewhat hard to come by at the big box stores like NAPA, AutoZone, or Advance Auto. With that said, excellent remanufactured parts can always be purchased from places like that. The more (not necessarily most) expensive parts that come with a lifetime warranty are usually my part of choice.
This is another area of car parts in which only three or four companies supply parts for the majority of the market. This means the exact same part is often sold at competing parts stores with only a different brand on the box.
Having worked for AutoZone, I can tell you that their Duralast hard parts are nearly always of excellent quality. Stay away from the cheaper Valucraft branded parts though. I had a lot of customers return them; particularly the older style Ford starters that don't have the on-board solenoid switch.
2007 Ion 2 Quad Coupe 5-speed manual 178K miles
2007 Chevy Equinox LT 187K miles
Add to ruley73's Reputation
Old 09-24-2010, 11:18 PM   #7
capricess
capricess has a spectacular aura aboutcapricess has a spectacular aura about
2001 SL
i got mine from advance it was a valeo rebuilt starter it works good. it was $118
Add to capricess's Reputation
Rate the quality of this post and help capricess reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
capricess is offline   Reply With Quote
Aftermarket Remote Starter -- SUCCESS!! tys Aura General 3 03-23-2013 09:29 PM
starter replacement eowynn L-Series General 2 07-02-2010 03:28 PM
aftermarket starter jackl S-Series Tech 4 12-26-2008 05:03 PM
Another brand of replacement H11 bulb tomlct L-Series General 1 10-08-2006 10:59 PM
WTS: Brand New 91-99 OEM Replacement Luk Clutch Kit LoveMySaturn Classifieds 3 06-10-2005 09:15 AM
