Old 02-04-2011, 09:59 PM   #1
trog69flh
trog69flh is on a distinguished road
1992 SL2
Dizzy 1997 sl headache
I NEED HELP
have a 97 sl2 that started acting up. started getting a misfire cylinder #3 fault. replaced coil packs (both) icm,plugs,wires, and injectors. the crazy thing will run great for awhile then ses light comes on and starts missing. when it runs great i can pull injector plug off and engine will miss, when missing if i pull wire off no change. had a noid tester on it and when it misses i have no juice to #3 wire at all, then juice comes back and tester works again.anyone have this type of problem. thanks for your help in this matter
Add to trog69flh's Reputation
Rate the quality of this post and help trog69flh reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
trog69flh is offline   Reply With Quote
Old 02-05-2011, 02:18 PM   #2
adventureoflink
adventureoflink's Avatar
Default Re: 1997 sl headache
Perhaps try cleaning/replacing the grounds to the injector and/or the main grounds (one behind the fuse box, the other on the engine underneath the EGR valve, and the negative battery connection)?
This is a weird fault.. normally when #3 misses, it's due to a clogged injector and can lead to burned valves..
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 02-05-2011, 03:03 PM   #3
Actually, there are no (direct) grounds to the injectors. They have a common hot (pink wire to each), and the ground for each is switched, selectively (sequentially) by the PCM. But it does sound like an issue with wiring to/from that injector (pink hot, pink/black ground, per '96 FSM).
Add to madpogue's Reputation
Old 02-07-2011, 09:40 PM   #4
trog69flh
1992 SL2
i have pulled all the grounds off and cleaned them. replaced both negitive ground ends. when it starts to miss i can shut it off and its like something resets cause when i fire it right back up then it run normal for awhile
Discontinued parts headache asdf S-Series General 14 01-31-2009 09:03 PM
Another starter headache bigbfarm S-Series Tech 14 09-28-2008 11:57 AM
1995 SL-1 giving me a headache Docwiggi S-Series Tech 8 03-12-2008 10:39 AM
97 SC2 sunroof headache PA97Saturn S-Series General 21 04-17-2005 02:12 PM
Electrical Headache... Terrandus S-Series Tech 8 03-11-2002 09:21 PM
