Old 11-13-2008, 11:48 AM   #1
00PowderSpecial
00PowderSpecial is on a distinguished road
2008 Astra XR
Default Saturn Astra and Oil Changes
So I'm sure I read in the owners manual that it tells you when it needs an oil change. So when I first got the car I put 2500kms on it and got an oil change because I was on my way to Ontario, and put 5200kms on that trip and figured for sure by the time I got home it would be telling me to change it. Well I've since drove another 7000kms and nothing telling me to change it. I've checked it on a regular basis, and theres lots of oil there, just off the full indicator. I'm just curious if anyone else is in the same boat I'm in, or maybe I have a bigger problem with a sensor not working.
Add to 00PowderSpecial's Reputation
Rate the quality of this post and help 00PowderSpecial reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
00PowderSpecial is offline   Reply With Quote
Old 11-13-2008, 12:19 PM   #2
L200Pilot
L200Pilot is on a distinguished road
L200Pilot's Avatar
2008 Astra XR
2002 L-Series 2.2L Sedan
Default Re: Saturn Astra and Oil Changes
Mine goes about 10,000 miles between the light coming on.
You know how when you first open the door, the odometer comes on? While its on, hold down the trip reset button, and it'll tell you how many miles/kms till your next oil change, rounded to the nearest thousand.
Welcome to SaturnFans!
The family:
1993 SL2: 051,000 mi (!)
1996 SL2: 260,000 mi (sold)
2001 SL2: 98,000 mi
2002 L200: 215,000 mi
2006 VUE: 50,000 mi (sold)
2007 Ranger: 40,000 mi
2008 Astra: 161,000 mi
Add to L200Pilot's Reputation
Rate the quality of this post and help L200Pilot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
L200Pilot is offline   Reply With Quote
Old 11-13-2008, 03:15 PM   #3
spencerb
spencerb will become famous soon enoughspencerb will become famous soon enough
spencerb's Avatar
2008 Astra XR
It's not really a sensor. It's an algorithm in the computer. The only thing that could go "wrong" with it would be that the computer failed (which would have many other symptoms) or the odometer display (where the "INSP" message appears) go out.
Just make SURE that when the oil is changed the monitor is reset properly. When it says you are due, it will show on the odo on startup for a few seconds (watch for this message to go away after a change if it's reset). If you get a change before it's due, use the method in the previous post before and after the change to make sure the miles/kms remaining goes up.
2008 BMW 328i
2013 Subaru Outback 2.5i Limited
Past Saturns: 97 SL2, 01 SC2, 04 VUE, 08 Astra, 02 L200.
Add to spencerb's Reputation
Rate the quality of this post and help spencerb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spencerb is offline   Reply With Quote
Old 11-13-2008, 04:01 PM   #4
BNM449
BNM449 is on a distinguished road
2008 Astra XE
I've used about a litre of oil in my XE's first 5200 km's. Is that normal?
~N~
Add to BNM449's Reputation
Rate the quality of this post and help BNM449 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BNM449 is offline   Reply With Quote
Old 11-13-2008, 05:45 PM   #5
KillerX
KillerX is on a distinguished road
KillerX's Avatar
2008 Astra XR
Ohh ohh I think I have a problem... I just went into Saturn yesterday for them to change to synthetic at 3200 and when I did the odometer thing today it says 17000 hmmm is there something wrong? I didnt even know if the guy knew how to reset the computer since he told me it was his first time changing oil on an astra thats why I went to check today
Brad
Add to KillerX's Reputation
Rate the quality of this post and help KillerX reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KillerX is offline   Reply With Quote
Old 11-13-2008, 06:42 PM   #6
L200Pilot
L200Pilot's Avatar
2008 Astra XR
~N~
Mine used some oil in the first 5000 miles or so, too. I think I had to put either one or two quarts in before the first oil change.
Since then, it hasan't burned any oil.
The family:
2001 SL2: 98,000 mi
Old 11-13-2008, 06:48 PM   #7
L200Pilot
L200Pilot's Avatar
2008 Astra XR
Brad
When I got my first oil change, they didn't reset it, so I had to figure it out pretty much on my own (that's how I discovered the British Astra fourms ). Also, when I got a flat tire, it took them 20 minutes to plug the tire, and another 90 to reset the TPMS
The family:
2001 SL2: 98,000 mi
Old 11-13-2008, 08:14 PM   #8
wandern
wandern is on a distinguished road
~N~
This is usually due to breaking in the engine too gently (not enough blowby past the compression rings to properly seat the oil rings). It's within "allowable" or "normal" limits, but it's certainly not optimum. Your oil rings will likely continue to seat a little more as the engine wears in, but it wouldn't be surprising if the engine always consumed some oil.
Add to wandern's Reputation
Rate the quality of this post and help wandern reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wandern is offline   Reply With Quote
Old 11-14-2008, 05:23 AM   #9
ruckbogers
ruckbogers is on a distinguished road
I would say there is no problem at all. I put in synthetic and mine also said 17000km till next oil change. As far as I understand it, it's "knows" your driving style and resets the counter to the appropriate KM to count down from. From then on it's based on engine revs, idling times, temp, etc that determines the rate it counts down.
Personally I'd say my driving conditions, "engine and oil wise" are very good; almost no short trips so the engine fully warms up, 80% highway, even in the suburbs there are long stretches where I can maintain 60km, the car almost lives in 5th gear.
But I haven't gone through the middle of winter yet so I suspect at my next oil change the INSP will indicate differently.
Add to ruckbogers's Reputation
Rate the quality of this post and help ruckbogers reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ruckbogers is offline   Reply With Quote
Old 11-14-2008, 07:10 AM   #10
72gssaturn
72gssaturn will become famous soon enough72gssaturn will become famous soon enough
72gssaturn's Avatar
2008 Astra XR
nothinf really wrong with a quart of oil used at 5200 km (3000 mi). as for me, i changed to synthetic at the firsrt oil change at 2000 km. the oil and filter will be changed at 6 months (about 6-7000 km). none of this 10000 km or once a year. changing the oil is cheap insurance and it does not last forever!
Gerry
72 Buick GS red
2008 Astra XR black 3dr
99 SL1
Add to 72gssaturn's Reputation
Rate the quality of this post and help 72gssaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
72gssaturn is offline   Reply With Quote
Old 11-15-2008, 10:28 PM   #11
m100
m100 is on a distinguished road
m100's Avatar
2008 Astra XR
How much longer do the rings continue to seat in terms of miles/time? The manual is not too specific in terms of break in. The serv. dept was even more vague. My prev. cars included more detailed guidelines in terms of mph/rpms ..etc. from a break in perspective.
"I love hot hatches..." Jeremy Clarkson
2008 Saturn Astra XR - Daily Driver
2005 Lotus Elise - Track Car
1991 Lotus M100 Elan - Project Car
Add to m100's Reputation
Rate the quality of this post and help m100 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
m100 is offline   Reply With Quote
Old 11-15-2008, 11:07 PM   #12
Layoira
Layoira is on a distinguished road
Layoira's Avatar
2008 Astra XR
I havent had to add any oil yet and I am at 6500 kms. I keep checking the levels and oil quality and all is fine. It has gone down a touch, but the oil to begin with from factory was higher than it should be, I guess for breaking in period. Im still well to the max level. Will be getting the oil changed in a weeks time even tho I still have 8000 kms at the moment until it indicates a change.
Add to Layoira's Reputation
Rate the quality of this post and help Layoira reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Layoira is offline   Reply With Quote
Old 11-17-2008, 08:00 AM   #13
72gssaturn
72gssaturn's Avatar
2008 Astra XR
if the rings are not seated by 2000 miles, u may ahave a problem.
Gerry
72 Buick GS red
99 SL1
Old 11-17-2008, 10:12 AM   #14
spencerb
spencerb's Avatar
2008 Astra XR
Mine has never used or lost a drop of oil since new. Gas mileage hasn't changed, either (been 30-35mpg). I did my first oil change at ~10K, and I'm due for another soon (have 19K on the car now).
2008 BMW 328i
Old 11-17-2008, 12:46 PM   #15
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
L200PILOT....the reason it took so long to reset tpms is that you dont have to. after driving the car it will reset itself on the astra...
Add to onefunkar's Reputation
Old 12-01-2008, 04:06 PM   #16
spencerb
spencerb's Avatar
2008 Astra XR
Originally Posted by Digency View Post
I just got an oil change this morning, the ODO read 15,232 KM and after it was done when I pressed the stem down it said the next oil change was due in 17,000 KMS.. is this normal or whats going on? Isn't that way too much KMs till the next change?
Yes, it's normal. In ideal driving situations, you can go that long on an oil change (contrary to popular belief). When it's reset, it goes to the max interval and then works its way down. The harder or less ideal you drive the car, the faster the remailing mileage goes down.
My driving must be ideal since I get about 10,000 miles between changes. When it's reset it goes to 11,000 miles.
Yours will start at 17,000km, but it may, for example, get to zero after only 10,000km if you drive harder or make a lot of short trips.
2008 BMW 328i
Old 12-02-2008, 09:32 AM   #17
Suns_PSD
Suns_PSD is on a distinguished road
2008 Astra XR
Lots of good info in this thread and it's nice to see at least a few people that understand a hard break in is VERY important to properly seat rings.
I liked the bit about hitting the odometer button after opening the door. Didn't know that one.
About 80% of engine break in occurs in the first 30 miles or so. It is EXTREMELY important that you drive the car until it is completely warm and then you run it up to redline several times and then let the motor coast down using the motor to slow the car in those first few miles. This will set the rings well. Then you should wait at least 5K miles to go to synthetic oil although waiting up until 10K is not a bad idea as that other 20% or break-in is still occuring.
If you did not break in your engine correctly your rings will likely never seat completely and the engine will ALWAYS burn some oil, and will always be down slightly on compression which hurts mpg and hp. It will also contaminate the oil early because of engine blow by.
The good news is the factory helped you tremendously as they already took your brand new motor up to redline under load several times when your engine was on a stand at the factory. If it wasn't for this there would be way more new vehicles burning oil.
For more info on how to properly break in any motor check out:
http://www.mototuneusa.com/break_in_secrets.htm
Add to Suns_PSD's Reputation
Rate the quality of this post and help Suns_PSD reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Suns_PSD is offline   Reply With Quote
Astra-nomical: Road Tripping in New Brunswick with a Saturn Astra Charlie Astra General 20 02-09-2018 05:21 PM
Opel Astra Sat-Nav for a Saturn Astra?? Merrimack2002 Astra Tech 11 06-20-2011 02:55 PM
Anyone try the oil extractor for Astra oil change ottastra Astra Tech 14 12-11-2009 03:20 PM
FS: 5-Pack Saturn Astra Oil Filters dmoser Astra General 10 01-21-2009 10:30 AM
Oil for the Saturn Astra Jamis Astra Tech 10 03-22-2008 06:41 PM
