Old 09-24-2014, 10:18 AM   #1
Jack Black
Jack Black is on a distinguished road
Jack Black's Avatar
1999 SW2
Default 99 SW2 rear disc conversion
Dorman C95198 cables correct for both sides for p cables? I read conflicting information about the brakes hoses.. Some people say the hoses from the drums are fine, while others feel there is not enough hose length for suspension travel.. What is most correct, the hoses are usable or there is a more proper hose? Would like to know before I change struts and spring height..
Add to Jack Black's Reputation
Rate the quality of this post and help Jack Black reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jack Black is offline   Reply With Quote
Old 09-24-2014, 02:05 PM   #2
SL19302
SL19302's Avatar
2002 SL1
Default Re: 99 SW2 rear disc conversion
When I did mine I used the disc brake hoses and removed the drum ones, I personally didnt want to worry about it and wanted it dont right, I would get the OEM park brake cables from the junkyard, Any 96-98 SL/SW with rear disc brakes the cables will be compatable.
CHECK YOUR OIL!
Add to SL19302's Reputation
Old 09-24-2014, 03:30 PM   #3
lamping.ap
lamping.ap will become famous soon enoughlamping.ap will become famous soon enough
The hoses are fine...
Add to lamping.ap's Reputation
Rate the quality of this post and help lamping.ap reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lamping.ap is offline   Reply With Quote
Old 09-24-2014, 04:49 PM   #4
Jack Black
Jack Black's Avatar
1999 SW2
Used cables would be easy enough, but they may be worn/stretched which is why I was asking about part numbers. I have a tendency not to trust used brake parts, sort of have my life on the line, so pulling used hoses would be done by me in an act of desperation to avoid being stranded. I questioning myself about replacing hubs when I get down to the project finally, simply because I would be in that point of disassembly.. However they are not making noise/rumbles yet. So I hymn and haw. I know it took some motivation to remove hubs from a donor car, and I wonder if the impact damaged the bearing, even though they are heavy duty.. Yes, I encourage to do things the right way, life's to short to waste to much time...
98 sw2 rear disc conversion hein S-Series Mods 18 04-04-2008 11:48 PM
FS: SL/SC Rear disc conversion coreyxh Classifieds 6 07-30-2006 09:21 PM
Rear disc conversion Masterson Ion General 7 09-06-2004 10:11 PM
Rear Disc Conversion SLeepr Classifieds 4 12-03-2003 07:51 PM
Rear disc conversion Bar(long a) S-Series Tech 7 02-23-2002 08:04 PM
