Old 09-15-2017, 11:15 PM   #1
SaturnHunter
SaturnHunter is on a distinguished road
Idea Rear Disc conversion
So I have a 2002 Saturn SL1 and I was wanting to do a rear disc conversion on it. Could anyone tell me what parts I would need from any other Saturn and possibly post links to a parts site that would have them? When I do the conversion I'm going to record it and post it on YouTube for others to learn from. Thanks
Add to SaturnHunter's Reputation
Rate the quality of this post and help SaturnHunter reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnHunter is offline   Reply With Quote
Old 09-16-2017, 08:19 AM   #2
Default Re: Rear Disc conversion
It's a direct bolt-on swap from any '91-'97 DOHC w/ABS (SOHC's still had the option of drums w/ABS '91-'97 but can be used if they have rear disc). Rear disc was dropped entirely starting in '98.
The only "gotcha" is the parking brake cables, for a SL/SW you should be good with cables for a '96-'97 SL/SW. The cables are the same length for both brake styles but the tab on the end of them are just enough different you can't swap between disc & drum. '91-'96 SC cables are roughly 3" shorter than every other model because their shorter wheelbase is taken out on the poor rear seat foot-well, so don't get those cables for any SL/SW.
I'll never buy another '80's/'90's GM with rear disc, the looks and ease of working on them is not worth the requirement of tearing apart every 4-6 months ('89 Gutless Supreme went through calipers yearly, 3 S-Series with rear disc had to at least be re-greased every 5-6 months if not replaced).
Old 09-16-2017, 09:01 AM   #3
There are a couple of brands of aftermarket brake cables that are too short, be careful as they will not stretch. You can go to RockAuto and look at the overall length and figure out which ones will fit. Do not buy off brand cables as they will not fit or last.
As fetch pointed out this is not a great idea of a performance increasing swap, it is a major continuing maintenance headache.
Old 09-18-2017, 12:37 PM   #4
And on the other hand, Luke mentioned that in the entire ~650,000 miles that he drove his Saturn, he did so on the original rear brakes - never replaced any part of the drum brakes
Old 10-08-2017, 07:55 AM   #5
Astrofarian
Astrofarian is on a distinguished road
Dizzy Re: Rear Disc conversion
So....apologies for thread-jacking here a bit but am I correct in concluding that this is a mod that I shouldn't consider? I THOUGHT discs on the rear would be an upgrade but the general consensus here seems to indicate that it's just adding a failure-prone headache to a perfectly reliable system. Can someone please clarify this for me?
-M!ke-
Add to Astrofarian's Reputation
Rate the quality of this post and help Astrofarian reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Astrofarian is offline   Reply With Quote
Old 10-08-2017, 08:21 AM   #6
Disc brakes require more maintenance than drums, this is made worse with rear disc on FWD cars...the moving parts never get moved to keep them freed up TO move so you need to re-grease them at least every 12 months. Half the rear disc S-Series I've had required new calipers because the idiotic parking brake mechanism seized up due to rust.
If you want better looks and don't mind higher maintenance then rear disc is fine, but unless I got a parts car of the same model as what you have now with rear disc...IMO it's just not worth the effort even for the "looks".
Old 01-15-2018, 02:48 PM   #7
S3aturnR
S3aturnR is a jewel in the roughS3aturnR is a jewel in the roughS3aturnR is a jewel in the rough
S3aturnR's Avatar
1996 SL2
1999 SL1
-M!ke-
it looks cool, but doesnít stop any better. itís surprisingly simple how easy this mod is, tho. if you skip the correct brake lines, you may end up paying for it with your life.
"reno is a lot like maybury, except everyone's on crystal meth and prostitution's legal" - junior
Add to S3aturnR's Reputation
Rate the quality of this post and help S3aturnR reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
S3aturnR is offline   Reply With Quote
Old 04-04-2018, 02:22 PM   #8
Highmile
Highmile's Avatar
I've replaced mine once. They were not really bad but with the age and miles one them I decided to replace everything.
Highmile
'95 SL1 654k and counting
Add to Highmile's Reputation
Old 04-05-2018, 06:32 PM   #9
PrestonIII
PrestonIII has a spectacular aura aboutPrestonIII has a spectacular aura aboutPrestonIII has a spectacular aura about
1994 SL2
1994 SL2
I vote for disk brakes:
I have a '94 SL2 HCE with an original 54K miles on it. A month ago, I put the first set of rear disk brake pads on it EVER in 24 years. The rotors didn't need replaced since they met thickness specifications, and the brakes didn't pulse beforehand. The rear pads were thinner than I expected, probably because the car has gotten such little use and the pads are always wiping away surface rust on the disk. That has likely taken it's toll. It doesn't pulse now either with the new pads. They did take a little longer time than normal to seat probably because of the original rotors. My personal choice for pads is a softer one. It saves the rotors and is less likely to squeal. On the other hand, it's hard to beat the original GM pads for longevity and noise issues. I got 67K miles on original front pads on an IROC-Z Camaro that I drove "quite vigorously". LOL
I only replaced the pads on my Saturn because I was replacing both rear wheel bearings for noise issues. Since I had it apart, I thought to replace the pads at the same time. My front pads are still original.
I'm unsure why everyone complains about pulling the calipers off the car.
With the right tools it's not a problem. I didn't even have to lay on the ground. There's a socket adapter called a "wobble" that makes quick work of it all. It's easier if you get the car way up in the air by jacking the whole rear end at once. For safety, do this on a flat concrete surface of course; no rocky driveway or dirt yard.
After 24 years my calipers weren't locked up and everything works well. I use the emergency brake once a week maybe to ensure that it stays loose. Though the driver's side rear caliper e-brake lever seemed to move a bit sluggishly, it freed right up with some spray on lithium lubricant and generous wiggling before reassembly.
Add to PrestonIII's Reputation
Rate the quality of this post and help PrestonIII reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
99 SW2 rear disc conversion Jack Black S-Series Tech 3 09-24-2014 04:49 PM
Rear Disc Conversion SL2-Guy S-Series Mods 4 08-17-2007 07:02 AM
For those with rear-disc conversion Vertigoomg Mods and Performance 15 10-21-2005 05:52 PM
WTS Rear disc conversion kit wink900 Classifieds 0 06-18-2005 12:08 AM
rear disc conversion twstdstrn S-Series Mods 8 08-01-2001 12:50 PM
