Old 01-05-2014, 05:55 PM   #1
jchu210
jchu210 is a jewel in the roughjchu210 is a jewel in the roughjchu210 is a jewel in the roughjchu210 is a jewel in the rough
jchu210's Avatar
Default p0420 code
on a 99 sc2 dohc auto 108K miles.
recently replaced:
front o2 sensor (denso)
entire exhaust system below the exhaust manifold
spark plugs (ngk) and ects with brass at 85K, wires 100K
egr ports cleared with compressed air 100K
random tidbits:
1. when engine is warm, after performing a complete stop, rpms dip momentarily and rises back to normal idle.
2. pulling the fuse for pcm-b does not work. ses light appears after car is started.
3. no egg smell
4. mpg has dropped from about 30mpg to about 24mpg
any advice is appreciated. I hope its nothing with the cat again, wouldn't be able to afford it. thank you.
auto 99 SC2, 110K miles
jchu210 is offline   Reply With Quote
Old 01-05-2014, 07:04 PM   #2
SL19302
SL19302's Avatar
2002 SL1
Default Re: p0420 code
Check for any exhaust leaks from the exhaust manifold to the Converter, Any leaks on the front pipe will cause that code, A shop vac with the hose attached to the blow setting works well in detecting leaks, Put the hose into the tailpipe to pressurize the exhaust system and spray down the front exhaust pipe with soap and water, The flex pipe and around the Transmission clamp are common places for the pipe to crack and rott and leak.
CHECK YOUR OIL!
Old 01-15-2014, 02:19 PM   #3
jchu210
jchu210's Avatar
this code was resolved today after i floored the pedal to WOT.
previously i try to keep it at 3000rpm or lower because of the oil burning, and i hadnt gone over 3500rpms for awhile.
seems like a little WOT every now and then is good for the car, for reasons i'd love to hear the explanation for.
also seems like the o2 sensor rear would have been the culprit in this case.
Old 01-15-2014, 02:26 PM   #4
TXSaturn02
TXSaturn02's Avatar
I've heard it called an italian tune up.
Some swear by it. Like a good sneeze maybe?
New owner report of 08/08/19: 234,408 Miles
As of 11/12/20: 78,895 Miles
Old 01-15-2014, 10:05 PM   #5
jhonky
jhonky is on a distinguished road
how recently did you do the exhaust? i just had the code but it was like 4 months after doing the exhaust so not exactly correlated. 108k seems awfully low for it to be a bad o2 sensor. my car had 202k before the rear o2 went bad
98 SL2
5th gear swap- .643 gear
245,000 miles
215/45 17"
I burn about a quart about every 1500 miles.
If it ain't broke, fix it some more.
jhonky is offline   Reply With Quote
Old 01-17-2014, 02:41 AM   #6
CND_SC1
CND_SC1 is on a distinguished road
1994 SC1
I hoped this gets rid of your problem. But wait a couple more days before closing the book.
My current car (02 Altima 2.5) has had a persistent p0420 since about ten days after I got it. Once in 2012 a passenger accidentally bumped the shifter in to N just as I was launching from a green light in the middle of a hill - the Tach needle spiked to 6500 for a moment and the SES light went out 2 seconds later, but it returned the next day after about 25 miles of driving.
CND_SC1 is offline   Reply With Quote
Old 02-13-2015, 07:37 PM   #7
jchu210
jchu210's Avatar
problem resolved,
it was the downstream O2 that caused this p0420.
light went away without manual reset within minutes.....
and the old downstream O2 sensor, at only 115K old, was pretty carboned up...
i probably won't see any mpg gains, but at least that light is off
Code P0420 DickG S-Series Tech 7 06-17-2013 03:34 AM
code P0420 ericfragola Vue Tech 18 01-23-2013 02:16 PM
'98 SL2 P0420 Code jhart S-Series Tech 52 12-17-2012 01:56 PM
help i got a code that is P0420 butters122706 L-Series Tech 0 06-13-2009 11:00 AM
Code P0420? DeMAN Miscellaneous Tech 3 08-09-2004 11:33 PM
