Old 06-20-2015, 10:53 AM   #61
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
Default Re: Richpin's How To Videos Sticky
New Videos
Saturn Ion Window Motor Regulator Removal
https://youtu.be/wkk4sMw4jWA
2000-02 Saturn S-series Radio Removal
https://youtu.be/Aqdv9U-ixQA
GM Ecotec 2.2L Crank Sensor Removal Cobalt,Malibu,Ion
https://youtu.be/5DRD5x0GUbo
GM 2.2L Saturn L,Ion Throttle Position Sensor Replacement
https://youtu.be/P-ErwUnZQrA
Saturn ION Blower Motor Resister Removal
https://youtu.be/sj62duBMhAA
Saturn S series Passenger Air Bag Removal
https://youtu.be/zDIxq0xIyfs
Hydraulic Floor Jack Bleeding & Fill
https://youtu.be/zPKsmRe7Fug
http://www.youtube.com/richpin06a
Add to richpin06's Reputation
Rate the quality of this post and help richpin06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
richpin06 is offline   Reply With Quote
Old 10-26-2015, 11:23 AM   #62
richpin06
richpin06's Avatar
New Videos
PCM Removal Gen 2
https://youtu.be/BBbFd0DMDhY
Homemade Engine PreOiler
https://youtu.be/3kM5rpuILJ8
Oil Pressure Switch Replacement
https://youtu.be/7Fzq6t6A9FM
Manual Transaxle Fluid Replacement
https://youtu.be/CRUz-Rjk3hc
Old 12-23-2015, 02:33 PM   #63
richpin06
richpin06's Avatar
New Videos
Ion Computer PCM Removal
https://youtu.be/r6tlt3LSIMQ
L,Ion Heater Hose Repair
https://youtu.be/JR9YeZysaZs
Dog Bone Motor Mount Replacement
https://youtu.be/jMnA1_ZA6iA
Old 02-24-2016, 04:07 PM   #64
RobertJ
RobertJ will become famous soon enough
RobertJ's Avatar
Thank you for all the updates Richpin. You have been a life saver to countless enthusiasts.
Past Saturns:
2002 SC2 5-speed
1999 SL2 automatic
2001 SC1 automatic
Current Cars:
1996 Jeep Cherokee 5-speed
2016 Ford Focus ST 5-speed
Add to RobertJ's Reputation
Rate the quality of this post and help RobertJ reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RobertJ is offline   Reply With Quote
Old 05-07-2016, 10:41 AM   #65
richpin06
richpin06's Avatar
New Videos
Saturn S series A/C Compressor Detachment
https://youtu.be/rVEb7kbJGGA
Saturn L Blower Motor Resistor Removal
https://youtu.be/iH8fLoV8xAU
Saturn S-series Windshield Washer Hose Replacement
https://youtu.be/TiOQWvFQ71s
Saturn Ion Blower Motor Removal
https://youtu.be/g8Yw0mOMD_c
Saturn Ion Ignition Lock Cylinder Removal
https://youtu.be/X1aPknAvXmU
Old 04-25-2017, 11:17 AM   #66
richpin06
richpin06's Avatar
New Videos
Clutch Interlock Switch Replacement
https://youtu.be/8WjDMXCkjIw
Crankshaft Position Sensor car not starting Test
https://youtu.be/vpUy8TeUgi4
Cooling Fan Troubleshooting
https://youtu.be/0E6vbQoXSqQ
Saturn Ion Clock Spring Removal
https://youtu.be/GiX-5gUtcF4
Basic No Start Trouble Shooting
https://youtu.be/TssJUFsV0Lw
Car Starts Slowly In Morning
https://youtu.be/MewOFsy5ss0
Brake Light Strobe Switch Installation
https://youtu.be/U_oWqcjTNHc
Old 09-09-2017, 10:45 AM   #67
richpin06
richpin06's Avatar
New Videos
Saturn Ion 05-07 BCM Removal
https://youtu.be/0hsafLXGu4g
Door Chime On With No Key In Ignition Or Lights On
https://youtu.be/Ubf9_MTHJKc
Old 07-13-2018, 11:00 AM   #68
richpin06
richpin06's Avatar
New Videos
Fender Emblem Removal
https://youtu.be/u--RPFJLxaw
Opening Hood with Broken Release Cable
https://youtu.be/u66t0xMHtEQ
Disabling Daytime Running Lights for Testing Purposes
https://youtu.be/i2J6otMcWzA
Front Fender Replacement
https://youtu.be/9OTpVOUXatU
Windshield Wiper Arm Repair
https://youtu.be/2Fb6nUxBIdE
Engine Removal part 1
https://youtu.be/hC_mF-m-Ua4
Engine Removal part 2
https://youtu.be/Dkjggw1k6xQ
Door Switch Replacement
https://youtu.be/IfUyS9o-EXc
Transmission Mount Replacement
https://youtu.be/36SgFoVkoyM
Old 08-21-2018, 10:38 AM   #69
richpin06
richpin06's Avatar
New videos
How To Do Compression Test
https://youtu.be/_HGW9DO2YKo
Checking Disc Brake Pad Thickness
https://youtu.be/q0fBewBXUXQ
Lubing Squeaky Windshield Wiper Linkage
https://youtu.be/--qiNxfcPFk
Removing Water Pump Pulley Without Using Impact Wrench
https://youtu.be/poq-t99k2Qk
Front Seat Removal
https://youtu.be/h3DR8T2UHFs
Car Will Not Run
https://youtu.be/BlWR-u1Bq00
Front Brake Replacement
https://youtu.be/ejumj-P8D3E
EVAP Purge Solenoid Removal
https://youtu.be/cnsvWf-FyKY
Side Marker Lights Flash (modification)
https://youtu.be/YTznly2V5tw
Vehicle Speed Sensor Location
https://youtu.be/ezLSiY8vH9Q
Fuel Filter Replacement
https://youtu.be/pRMz1VASzpY
Oil Change Tru Wheel Well
https://youtu.be/3waJw-CmOSI
watching Richpin's GPS video dorisSL S-Series Tech 5 01-29-2009 01:55 AM
richpin's video - battery hold down removal bez S-Series Tech 14 10-15-2008 11:51 AM
Videos of Astra!! alfkorda Astra General 5 12-18-2006 04:51 PM
0-60 videos golftango Ion General 31 10-07-2003 08:30 PM
Installation videos sc288203 Mods and Performance 6 05-06-2003 04:04 PM
