Old 06-27-2018, 07:20 PM   #21
DonP1
DonP1 has a spectacular aura aboutDonP1 has a spectacular aura aboutDonP1 has a spectacular aura about
Default Re: Just picked up a 2001 dark metallic grey SL2 Auto
Thanks guys. I'll check this out tomorrow when the weather is better.
Add to DonP1's Reputation
Rate the quality of this post and help DonP1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DonP1 is offline   Reply With Quote
Old 07-12-2018, 08:26 PM   #22
DonP1
1- OBD II pinouts are shown in drawings. Check for a blown or missing 10 amp BODY fuse. Pin 2 Is the serial comm line, pins 4&5 are grounds, and pin 16 is power to the OBD II port from the 10 amp fuse.
Winner! You nailed it. Someone pulled the Body fuse. And when I plugged it in I found out why. The door locks kind of go crazy locking and unlocking rapidly. I pulled the relays for now.
I was able to read the OBD port and pull a list of error codes.
codes:0117,0118,0125,0133,0340,0341,0710,0714,0741 ,0781
0118 description : "Engine Coolant Temperature Circuit High
0117 description : "Engine Coolant Temperature Circuit Low
0781 description : "1-2 Shift",
0741 description : "Torque Converter Clutch Circuit Performance or Stuck Off
0125 description : "Insufficient Coolant Temperature for Closed Loop Fuel Control
0714 description : "Transmission Fluid Temperature Sensor "A" Circuit Intermittent
0133 description : "O2 Sensor Circuit Slow Response
0341 description : "Camshaft Position Sensor "A" Circuit Range\/Performance
0710 description : "Transmission Fluid Temperature Sensor "A" Circuit
0340 description : "Camshaft Position Sensor "A" Circuit
Guess I got stuck with some fun with this one.
Old 07-12-2018, 09:54 PM   #23
That fuse was probably pulled on purpose for the sale. With so many error codes, it may be easier to try a manual reset then see what comes back.
1996 SL2 auto 127,700 miles $1800.00-San Diego-dark green sdheavymetal Classifieds 0 09-17-2017 01:18 PM
Saturn driver-side front body panel needed - dark grey Bubs S-Series General 11 04-04-2009 12:01 PM
L 300 dark blue 2001 billbat L-Series General 0 10-01-2008 09:23 AM
92 SL1 auto. parts (grey) gourd Classifieds 0 08-01-2005 10:36 PM
QC3 Bright Blue Dark Grey Leather luteplayers Ion General 11 05-27-2003 05:00 PM
