#1 |
![]() Join Date: Jan 2016
2007 Saturn Ion 3 with 2.2 liter engine.
Son was driving it. He said the check engine light came on, and there was a loss of power. I just read the codes: P0121 – Throttle / Pedal Position Sensor / Switch A Circuit Range / Performance P2135 – Throttle / Pedal Position Sensor / Switch A/B Voltage Correlation So I did a little research. There is a throttle position sensor on the throttle body. Could this be the culprit? If so, I don’t think I can purchase just the sensor – I think I have to purchase a whole new throttle body. A little more research shows there is an “accelerator pedal position sensor.” Is this a different sensor? Is it a sensor attached to the pedal? |
#2 |
Examine your throttle body. If it has a steel cable to operate the throttle valve then your pedal isn't electronic.
Improvements in throttle bodies allows replacement of its throttle position sensor. Check rockauto online for parts or GM online parts. |
#3 | |
![]() Quote:
There's no special programming required after doing this, but you'll need to clear the codes so the ECM can relearn the throttle plate's fully open/closed positions. This may take several drive cycles and the engine will idle high (around 1000-1500 RPM) until it's complete. It took about a week of daily driving for the idle in my Ion to return to normal after cleaning the throttlebody. My 2007 Chevy Equinox behaved the same way after cleaning the throttlebody just a couple months ago. It wasn't throwing any codes beforehand. I just cleaned the throttlebody while replacing the lower intake manifold gaskets. The last time I cleaned it was over 10 years ago, so it was pretty dirty.
2007 Ion 2 Quad Coupe 5-speed manual 183K miles *gone* 2007 Chevy Equinox LT 214K miles 2018 Chrysler Pacifica Touring L 93K miles Last edited by ruley73; 01-23-2023 at 09:25 PM. |
Bookmarks |
2007 Saturn Ion Throttle Body Position Sensor Issue | TenaciousMe | Ion Tech | 4 | 03-06-2023 03:41 PM |
2000 Saturn SL2, Self Revving Engine, Coolant Sensor or Throttle Position Sensor? | aygc271 | S-Series Tech | 5 | 08-06-2018 08:39 PM |
07 ion P2135: Throttle/pedal position sensor switch "A'/"B" voltage correlation. | uposb4 | Ion Tech | 2 | 07-20-2017 11:07 PM |
Pedal position sensor | Natural | L-Series Tech | 3 | 02-14-2017 05:57 PM |
Problem with throttle body position sensor? | munky000527 | Ion Tech | 15 | 01-21-2011 01:24 PM |
