Old 12-21-2022, 10:59 AM   #1
StuIon3
StuIon3 is on a distinguished road
Dizzy Saturn stops running
My 2004 Saturn ion sedan, 2.2 of course starts fine. But it the motor will stop running either at idle or on the road. I pull to the side of the road and if I just try to crank it back up it won't restart. IF I remove the key from the ignition and put said key back into the ignition it fires right up. I have to remove the key and reinsert every time or it will not fire back up. All sensors have been replaced, including the coil pack TBS and idle motor. This is an engine I rebuilt myself. Engine runs fine otherwise. Also I did drain the tank and it has fresh gas. I'm puzzled!!!!! Oh no check engine light.
StuIon3 is offline   Reply With Quote
SL1 stops running for no reason! rocketdog S-Series Tech 5 11-12-2011 11:02 PM
Saturn stops while idling iowakirkwood S-Series Tech 3 01-11-2009 10:30 PM
2000 ls2 stops running mbkustom L-Series Tech 5 02-13-2006 06:35 PM
92 SC2 stops running after aprox 5-10 minutes Daryl92sc2 S-Series Tech 10 06-03-2005 11:02 PM
running after engine stops rerun S-Series General 4 03-04-2005 01:31 PM
