#1 |
![]() ![]() ![]() ![]() Join Date: Jul 2022
Say, does anyone know if I can add a jacked-up tilt sensor to my OEM alarm on my stock 98 SC2?
I live on the westside and the meth heads are stealing Catalytic converters like crazy. But on my 98 Saturn they'll have to jack it up first to get to the Cat. I'm assuming my factory key fob alarm doesn't have a tilt sensor. I'm wondering if it's possible to add one as a trigger for the alarm. I know they sell tilt sensors separately for alarm systems. Any info on this would be appreciated. Thank you Jim |
#2 | |
![]() Quote:
long answer: how good are you with electronics? with an arduino-compatible microcontroller and an accelerometer module it'd be quite achievable on a very small budget, but it's far from plug-and-play. ultimately there are a couple inputs you could trigger on the oem alarm to set it off, the real trick is how to determine when that should happen. if you want to integrate an oem tilt sensor from another car, i'd get one from the jy and tie it into the door switch circuit. the oem alarm goes off if you open a door, so that's the simplest path to accomplish your goal. you may need a logic/voltage shift depending on what car you pull the sensor from.
rings-1996 sl2 ~215k mi phoebe-1995 sl1 ~250k mi janus-2000 sohc2 ~190k mi tethys-1994 sw2 ~302k mi rip mimas-wrecked 1996 sw1-trailer pandora-1999 sc2 dione-1998 sw2 penny [iapetus]-1997 sw2 |
#3 |
![]() ![]() ![]() ![]() ![]() Join Date: Mar 2017
1995 SW2
Your cat is worth maybe $60 (that is what I sold my 1995's cat for during the peak of the prices). Tape a note with it's value next to it, I am sure they will be lazy and not cut it out for a meager pay day.
1994 Sl2 5spd: First Car, Stock: 56,576 (Totaled 1/10/2018) 1994 Sl1 5spd: Inherited, Stock: 495,000 1995 Sl2 5spd: Retired Daily, Not Stock: 198,000 1995 Sw2 5spd: Daily, Stock: 110,000 |
#4 | |
![]() Quote:
personally, i just rely on the low ride height of my cars as a deterrent, i was parked right next to my coworker who had his cats stolen and janus was untouched... but there are areas where people are desperate and determined enough that they will bother to jack up a car to get the cat.
Bookmarks |
jack stands and floor jack | jonny772 | Ion General | 26 | 01-13-2019 09:36 PM |
HOWTO: Integrating tilt sensor into existing alarm | glenstewart | How-To Library | 1 | 11-03-2012 01:30 PM |
UW Leak detection.. | off-track | S-Series Tech | 7 | 05-07-2009 08:56 AM |
Oil Leak Detection | gmschrank | S-Series Tech | 2 | 05-14-2006 09:51 AM |
Where to put jack stands and jack up a 1996 SL2 | almies | S-Series General | 2 | 10-25-2005 03:13 PM |
