Old 09-14-2022, 02:05 AM   #1
Vellyn
Vellyn is on a distinguished road
1997 SW2
Wrench 1997 Saturn SW2 (HELP)
The car just recently got a new battery (for the 4th time). Now has a new alternator (2nd one so far), a new starter, a new master cylinder, and new bolts for connecting the cables into the battery. As well as a new air filter. And new spark plugs.
Just recently, for no obvious reason, the lights started going dim inside the car, then flickering, then the gauges started going haywire, the battery light was constantly flickering. The rpms went up but the car was barely getting up and going (basically like it was being pulled backwards while you are trying to go forward) shifting hard at times.
The alternator is brand new, just replaced. The battery is brand new as well. We have new spark plugs and air filter... all the fluids are at the point they need to be...
What is going on? We really don't want to sell it but we are stumped as its electrical or not? Bad ground? A short? Fuse? Relay? Sensor?
Open to anything we can test and/or try at the very moment. We need every bit of advice possible!!!!
Vellyn is offline   Reply With Quote
Old 09-14-2022, 08:57 PM   #2
hholbein
hholbein is just really nicehholbein is just really nicehholbein is just really nicehholbein is just really nice
1997 SW2
Default Re: 1997 Saturn SW2 (HELP)
I'd definitely check cables. wiring, and grounds for corrosion and resistance before you fire the Parts Cannon off again. I don't know whether you're in the salt belt, but if so, that would make me double down on testing the wiring/grounds.
Is yours a duplicate post? I see another one here with similar sound advice from waiex191 and fdryer
http://www.saturnfans.com/forums/sho...d.php?t=272820
Old 09-15-2022, 12:54 PM   #3
Duner
Duner is on a distinguished road
1998 SL1
As has been said, check your grounds.
I just add jumper cables all over the place. Cheap ,easy and fast as long as you don't have to drive the car to see a change.
Duner is offline   Reply With Quote
1997 saturn lumpyyy General Saturn Discussion 1 05-18-2011 12:29 AM
My new 1997 Saturn Sl2 125,345 a33009 S-Series General 3 02-26-2010 11:49 AM
1997 Saturn SW luvtwin S-Series General 22 04-27-2007 01:58 PM
1997 Saturn SL2 giger S-Series General 1 05-15-2006 10:24 PM
Looking at 1997 Saturn SC2 bromeoSC2 S-Series General 5 05-26-2005 03:14 PM
