Old 09-06-2022, 07:05 PM   #1
nickaa827
nickaa827 is on a distinguished road
Question Ac compressor Ground (?) Wire slightly melted
Hello everyone. This question is relating to our 2003 Saturn Vue 3.0 AWD. We have had no ac for awhile now and we figured out the connector going to the Ac compressor has been slightly cooked. I shoved a a piece of wire in the connector and sure enough we have ac again. Why did the connector melt (see video)? How do I check if there's an issue with the ground connection?
Video of connector: https://imgur.com/a/Rrv17qK
nickaa827 is offline   Reply With Quote
Old 09-07-2022, 08:16 PM   #2
Default Re: Ac compressor Ground (?) Wire slightly melted
Unless the ac connector was tapped to supply power to an aftermarket device, the severely melted connectors may be just an unusual case of a loose connection. Several amps power the ac compressor magnetic clutch coil and runs continually with ac use (no power cycling of Saturn compressors). If you can, replace both connectors, splicing in a new or used set. It's not worth worrying or second guessing why this connector melted other than a loose connection. The best you can do when replacing the connectors is monitoring current draw. My guess is no more than 5-8 amps are used.
Old 09-07-2022, 08:49 PM   #3
nickaa827
Heart Re: Ac compressor Ground (?) Wire slightly melted
Thank you
Tags
air conditioner, vue
Melted yellow “L” wire on alternator danielcg S-Series Tech 3 10-24-2018 03:02 PM
Ignition Switch Pluggin Wire Melted dcole2525 S-Series Tech 12 10-29-2012 01:44 AM
transaxle buss plate slightly melted mehalski S-Series Tech 2 08-07-2007 09:30 PM
? On Melted Wire in Harness Ragucci05 L-Series General 2 02-08-2007 08:29 PM
Where to Ground Wire ? tenn734 S-Series Mods 5 12-23-2005 12:22 PM
