#21 |
![]() ![]() ![]() ![]() Join Date: Apr 2000
2007 ION-2 Quad Coupe
1997 SC1
I've had good luck with KBS brush on high temp coating on cast iron manifolds.
The cleaner the better...if you can get it bead blasted that's a good prep. https://www.kbs-coatings.com/high-te...re-paints.html |
#22 |
![]() ![]() ![]() ![]() Join Date: Apr 2014
so that cleaned up way better then I thought
put new lifters in re-assemble see what happens reusing the lifters is silly for how cheap they are nobody likes a ticky motor its hard to tell but I don't see a lot of cross hatching left on the piston bores which means its pretty worn out but ... send it |
#23 | |
![]() ![]() ![]() ![]() ![]() Join Date: Jun 2015
2006 RELAY-2
2007 ION-2 Sedan
![]() Quote:
Also, how could I tell if the hydraulic lifters can be reused or need replacing? Got a new head that came with new valves, valve guides springs, retainers, keepers, studs, even came with the pieces that hold down the camshafts (don't know what they're called). Got the gasket kit and spark plugs. Ready to install it. Just need to find out about the litters |
#24 | |
2006 RELAY-2
2007 ION-2 Sedan
![]() Quote:
There is the hayns manual and other people online saying how it should be, then someone online going off of the Saturn factory repair manual. We have it to where the copper and black links (black is silver in the Haynes manual) line up on the gears like in the manual illustration but he's honestly not sure. I think he'll eventually figure it out but it's just he likes to go by the book as much as possible and it's confusing and sometimes contradicting, I guess This particular chain has 2 copper links and a black one (silver in the manual). Actually, one of the copper links is kinda half silver either by design or discolored/"smudged" looking from scraping against something? Thanks |
#25 |
In every timing setup of 4-stroke engines, cylinder #1 is used for TDC when both intake and exhaust valves are closed. With 4-stroke engines, two full revolutions (720 degrees) of the crankshaft is required to get to tdc. Assuming nothing, rotate the crank until cyl#1 exhaust valve begins to open. As the crankshaft rotates and closes cyl#1 exhaust valve, tdc is reached. Continuing past tdc, the intake valve begins to open, past tdc. When the intake valve opens and closes, 180 degrees of crank rotation will occur. This is not tdc (only 180 degree of 720). Intake closing begins the combustion cycle for another 180 degrees before the exhaust valve opens, needing 180 degrees to open and close where TDC occurs to begin another 4-stroke cycle.
A straw inserted into cylinder#1 can help visualize piston travel relative to intake and exhaust valve opening/closing while viewing both valves. When timing is correct, several crankshaft revolutions (two revolutions per 4-stroke cycle) should occur without pistons meeting valves. There should a few youtube videos for 2.2l ecotech engines since GM used them in several models. |
#26 | |
2006 RELAY-2
2007 ION-2 Sedan
![]() Quote:
After putting everything back together it started up in less than 30 seconds. Smoked for a good bit due to spilled fluids like oil and coolant from when unhooking things but eventually stopped. It drives pretty good but sounds kinda ruff when accelerating in the first few gears. Accelerates normally. There is a camshaft sensor code (I think that's what it said. Hopefully nothing major and something easy to resolve. Wish I knew what was making it sound louder than usual when accelerating in the first few gears. Maybe it just needs to brake back in? Hope so. Gotta tune it up. Oil change, maybe a coolant drain and fill, etc. Also needs a new ignition switch. Had to start it by hooking the starter up to the battery post. Had a few bolts and nuts leftover that I couldn't remember where they went smh. Two of them were long like 5-7 inches and it bothers me. Hope the engine doesn't pop out while I'm doing 70 down the highway. ![]() Thanks to everyone who helped me out! |
#27 |
The noise may be from the bottom end, maybe connecting rod bearings. When the valves met pistons with skinny valve stems bending, the shock is sent everywhere. Con rods can bend/break, wrist pins may crack pistons, crankshaft plain bearings squish, etc. Anything imagined is answered with a full tear down. Guessing is easy.
#28 | |
2006 RELAY-2
2007 ION-2 Sedan
![]() Quote:
#29 |
The positive side of this is a great budget rebuild. Unfortunately, running at idle places zero load on the engine. Once loads are engaged, driving, expert engine rebuilders with extensive experience may be the only ones to know what engine parts are damaged. A video recording (explaining what occurred to bring you to a budget rebuild) put on YouTube asking for suggestions may help with a link to this site.
#30 |
![]() Join Date: Nov 2022
The cost varies. It depends upon the seller.
Bookmarks |
GM L81 3.0L V6 Engine - Head Gasket Replacement (Questions for DIY) | BrandonKastning | L-Series Tech | 9 | 07-04-2020 10:16 AM |
SC2 Head Replacement | Rknow82 | S-Series Tech | 27 | 02-22-2014 09:34 PM |
Head Replacement. | Crasoum | S-Series General | 7 | 08-02-2008 03:50 PM |
after head replacement.... | the_skin_eater | S-Series Tech | 7 | 05-17-2005 12:42 PM |
95 SL Head Replacement | roger | Miscellaneous Tech | 7 | 02-25-2001 03:16 AM |
