Old 09-02-2020, 09:05 PM   #1
Lew992001
Lew992001 is on a distinguished road
Default Poor gas mileage
My vehicle is getting very poor gas mileage! I have an OBD reader so I did a live read on it and the maf sensor was reading very high so I took it off and cleaned it but now it's reading normal again and it's getting worse mpg I also replaced the map sensor! Anyone else have this issue and what was done to correct it?
Lew992001 is offline   Reply With Quote
Old 06-26-2021, 01:29 PM   #2
bordermec
bordermec is on a distinguished road
Default Re: Poor gas mileage
Last statement That made no sense at all.
bordermec is offline   Reply With Quote
Old 10-18-2021, 05:43 PM   #3
Dusty Trigger
Dusty Trigger is on a distinguished road
Clean your fuel injectors and whole gasoline system as it can be gummed up, etc. causing injectors to spray incorrect mist pattern and using too much fuel.
I have used Chevron Techron Concentrate Plus Whole Fuel System Cleaner as needed (Walmart $4.94/10 oz, etc.) to now use much less fuel at idle and improve acceleration.
Chevron originated the Nitrogen Based Fuel Cleaning Additive that must be used to be effective.
Dusty Trigger is offline   Reply With Quote
Old 10-18-2021, 07:58 PM   #4
jbuenavides
jbuenavides is on a distinguished road
Here is a detailed answer to this inquiry:
https://www.carsdirect.com/car-buyin...ad-gas-mileage
Feel free to read it when you have the time.
jbuenavides is offline   Reply With Quote
Old 10-29-2021, 01:33 PM   #5
Doug C
Doug C's Avatar
2008 Outlook XE
Idea Re: Poor gas mileage
It made sense !
A reading can start looking good after the MAF cleaning (and possibly a new air filter if due or dirty), but still have worsening mpg indicating the MAF was not the cause !!
ex. I recently acquired a '96 gmc sierra k1500 with minor issues, subsequently I uncovered after market add-ons within the air intake hosing, cleaned the MAF sensor with CRC' (as I read that contamination of the unit could cause the negative symptoms showing), and replaced hosing & the compromised manifold adapter to shed the add-ons a previous owner had installed presumably for better mpg, but the engine still 'stutters' when idling at a stop .
p.s. what Outlooks are you all driving ?
poor gas mileage dude33333 S-Series Tech 17 05-10-2015 03:06 PM
Poor mileage Bustinlips S-Series Tech 4 11-25-2011 07:09 PM
Poor gas mileage insphats Vue Tech 5 07-14-2011 11:12 AM
Poor Gas Mileage George Lopez S-Series Tech 10 02-06-2006 06:48 PM
Very Very POOR Gas Mileage? jman Mods and Performance 6 12-28-2000 01:19 PM
