Old 06-01-2014, 02:55 PM   #1
2003mnsaturn
2003mnsaturn is on a distinguished road
Default Fuel tank ground strap
I just got done replacing the fuel pump on a 2003 L 200.
When I was removing the bolt for the fuel tank ground strap, the head broke off the bolt.
Do I need to re-mount the ground strap, or can I let it dangle, or even cut it off?
2003mnsaturn is offline   Reply With Quote
Old 06-02-2014, 04:36 PM   #2
pierrot
pierrot's Avatar
Default Re: Fuel tank ground strap
I would definitely remount the ground strap. The manufacturer put it there for a reason, it wasn't accidental. Failing to utilize the ground strap could lead to other electrical problems. Leaving it disconnected, or removing it, is not worth the risk of more trouble.
389K miles (engine replaced @ 375K).
Biden/Harris predictions, '21 -'25: weak economy; weaker military; more terrorism; emboldened RED CHINA. Sadly, B & H are proving me correct.
Ground strap scalemechanic S-Series General 11 04-10-2018 05:54 PM
fuel tank strap vintagegz Ion General 4 04-20-2016 12:49 PM
PO442 and ground strap scalemechanic S-Series General 5 08-25-2013 04:17 PM
Fuel Tank Strap Bolt size satrnfan S-Series Tech 3 10-22-2012 04:12 AM
Ground strap needed? satrunracer S-Series Tech 2 09-29-2001 07:49 PM
