#21 | |
![]() Join Date: Sep 2015
Thanks again for your reply. I have that picture but cannot find the location of those 3 bolts. I initially removed the wrong ones until i realized it didn't help me at all lol. I have removed the seat as you suggested previously. I also removed the storage compartment / dash panel. I'm left with the steering column / shaft that is blocking the metal bracket for the clutch from being able to remove unless i remove the master cylinder (which seems like a HUGEE headache) Any other way to help identify the correct bolts you are referring to? Do I need to take off trim panels to see them? How about the bolts underneath the steering wheel itself? removal necessary? |
#22 |
THANK YOU THANK YOU THANK YOU
RULEY I Greatly appreciate your replies, and pictures! I probably wouldn't have gotten this done if not for this thread. I've replaced the clutch pedal (due to broken spring) as well as the top travel position switch. Which now gives me cruise control, and my clutch feels like when I first got the car!! WOO HOO!! Thanks a lot everyone! Happy banana here ![]() |
#23 |
![]() Join Date: Mar 2016
OK, so I just had to do this repair on my wife's '06 Ion, and I could not figure out how to get the steering column off without completely demolishing the dash. I kinda hulked out, and got the old one out by bending the plate with the two bolts holes and the hole for the master cylinder in a few MM to get clearance over the two studs. I did it with pure rage, but a big screw driver should also work. Before putting in the new one, I used a fiber cutting wheel on a rotary tool to cut a ~3mm V notch out of the top of the two reinforcing rings at the top so the new pedal could slide in over the studs. Seeing as the backing plate bends with only moderate effort, these rings are more for positioning than reinforcement so I don't anticipate any detrimental effects, but please only use this technique if you understand and accept the risks. Also, be aware that the new part is slightly different than the original, and the stud they pre-load in the pivot joint pushes in once the pedal is in place.
#24 |
![]() Join Date: Dec 2010
I just replaced my clutch master cylinder, piston rod broke just bellow plastic ball.
Clutch pedal removal was not necessary but I did anyway to check for wear at pedal-master cylinder contact point. Both had friction wear. I was able to still use the old clutch pedal with new clutch master cylinder although some pedal play was evident once fully put together. After reading the comments on this tthread I'm left wondering how you guys use the zip ties to limit pedal travel (picture would be perfect). I also read about a pedal bushing, where would this bushing go, my pedal is 1 single unit, no parts on it seem to be replaceable. My car is a 2004 ion 3 . Thanks for your help guys. |
#25 | |
![]() Join Date: Feb 2019
Hey I know this thread is dead now but I have the same exact problem and I was wondering if you had any reference photos or any other details about doing this job. My local guy quotes me $730 for a new pedal and master cylinder but I know I can Macgyver a fix. I actually shoved tin foil into the cavity initially for a quick fix but eventually the worn down ball joint just broke up inside the bushing. Now I just have a rod with no ball joint and a massive cavity where the bushing should be. I'm thinking about using your o-ring idea and creating a new ball-joint like shape out of some jb weld putty possibly.
So you said you didn't have to take the actual pedal out of the car when you did this? Do you have to take the steering column apart to get to it properly? Thanks Quote:
#26 |
![]() Join Date: Jan 2023
I changed my clutch pedal. Can not figure out how to get the ball on master cylinder to stay in pedal?? Am I missing something.
#27 |
My clutch pedal on my 05 ion coup needed to be replaced. My friend came up with this solution since it was a huge discomfort in the buttocks. Leave the old bracket in place and just zip tie the spring to the new pedal. Then replace the old pedal with the new. It's hardly a stroll in the park, but it helps.
No clutch pedal after replacement. | N_da_mood | S-Series Tech | 1 | 08-19-2013 12:02 AM |
Replaced clutch - Now clutch pedal too light and engagement not correct | jk3006 | S-Series Tech | 23 | 07-21-2013 07:49 AM |
Replaced clutch hydraulics now clutch pedal won't depress - Help | GPCBAKER | S-Series General | 17 | 03-13-2012 01:01 PM |
no clutch pedal | steph4 | S-Series Tech | 6 | 03-19-2010 12:53 AM |
Clutch fluid level, clutch pedal vibration, small leak | Heartbeat - '95 SL2 | Miscellaneous Tech | 10 | 10-10-2003 06:35 PM |
