![]() ![]() ![]() Join Date: Jan 2010
2003 ION-2 Sedan
Lowering my son's car and came to a seized adjustable (non-factory) camber bolt. the other three factory bolts did not present any problems. I cannot hammer it out no matter what I do.
HELP??? |
![]() Join Date: Jun 2021
2005 ION-2 Quad Coupe
The hole the camber bolt goes through should be slotted. Make sure you twist the bolt so the cam aligns with the hole.
You are probably not aligned and getting caught on the lip. |
2003 ION-2 Sedan
That's what I thought. But, it was just seized. I heated it with a torch, whacked with a sledge hammer, and in the end cut it off with a grinder. only took 90 minutes on the whole strut rebuilt/lowering springs install...
02 SL2--Lower Control Arm/Ball Joint: Seized Bolt | Hiram_32 | S-Series Tech | 59 | 12-13-2018 10:38 PM |
camber bolt swap out? | fetchitfido | S-Series Tech | 4 | 04-27-2012 08:06 AM |
Seized brake caliper bolt. | Eliot | S-Series Tech | 28 | 09-25-2011 03:22 AM |
Bolt seized and now cannot adjust rear toe during alignment...HELP!!! | cavalier | L-Series Tech | 1 | 07-06-2010 04:31 AM |
loose camber bolt? | xupthree60 | S-Series Mods | 8 | 11-23-2006 05:25 AM |
