#1 |
![]() ![]() Join Date: Sep 2011
2001 SC1
I ran across this Saturn ion on marketplace. They're asking $1400 has 179,000 miles they have owned it 59,000 miles. It is a manual trans. They mention the axle is making noise at any speed while turning. I imagine it just needs an axle shaft. That being said I've only owned s series Saturn's so moving into an ion is an all new beast. What should I know? Pros and cons to the ion? Things to watch for? I appreciate all the Info and insight. Thanks everyone!
#2 |
![]() ![]() ![]() ![]() Join Date: Apr 2000
2007 ION-2 Quad Coupe
1997 SC1
I think the Ion is under-appreciated.
You get the rustproof body with the GM delta platform high volume production thus wide ongoing availability of most parts. If you can do your own labor on repairs, you can run for a long time without spending a lot of money. |
#3 |
![]() Join Date: Jan 2014
2006 ION Red Line
Ion's can be great cars, and if it has the 2.4 Ecotec it should pull the car along quite nicely with 170 hp. The 2.2 is alright too, but does not have the grunt of the 2.4.
Things to look out for: ask if the timing chain/ guides have been replaced. The timing chains on these are known to fail suddenly and will ruin the motor. Oil leaks, from the valve cover usually. The front end will probably need work by now, but for sure the steering intermediate shaft will need to be replaced unless it's already been done. Not expensive but annoying. There were also several important recall's that should have been done by now: the air bag, ignition switch and if you are lucky, the fuel pump assembly. The Ions are known to have rust issues on the fuel lines and pump areas causing fuel leaks. If you smell gas around the fuel tank under the car walk away, because I think GM will only fix this if the car has under 150 miles on it. That said, this may only apply to the Ion Quad coupes, not sure.... Hope this helps, good luck!
My 96 SL2 and 98 SL1 have joined together to become one. So I guess I now have a 1996/8 SL1-2. |
#4 |
'There were also several important recall's that should have been done by now: the air bag, ignition switch and if you are lucky, the fuel pump assembly.'
Also the power steering electric motor. An '04 with a manual lets you avoid the Quad coupe's CVT [vTi] disastrous continuously variable transmission. OP: did you buy it? I've had my 05 ION 1 since new. If anything happened to it I'd buy another one, actually. |
Bookmarks |
can a four door ion 2.2L I4 be a quad coupe? | paulclawson3 | Ion General | 9 | 07-05-2012 11:27 AM |
Looking into buying a Ion Quad coupe | houstontexanfan | Ion General | 11 | 03-05-2009 11:08 PM |
Planning on buying a new ion quad coupe | allenkm | Ion General | 7 | 07-09-2005 01:08 AM |
Shift knob for manual 03 ion 3 quad | IonBryan52 | Ion General | 2 | 12-01-2004 02:20 AM |
Quad Coupe or 3 door SCx? | Arnel | General Saturn Discussion | 30 | 03-09-2004 12:18 AM |
