Old 09-09-2022, 09:59 AM   #1
skinned-knuckle
skinned-knuckle is a jewel in the roughskinned-knuckle is a jewel in the roughskinned-knuckle is a jewel in the rough
Default Flashing Warning Lights and Bouncing Gauges
https://drive.google.com/drive/folde...L3?usp=sharing
See linked video. 2007 Saturn Ion. My buddy's daughter is hours away from home at college (closer to me than her family) and this just started. The warning lights are flashing on and off and the temp, rpm and speedo gauges drop to zero and bounce back. The car is starting and running fine so far. I want to make 1 hour trip to help sort it out if I can.
Any suggestions are appreciated. Could it just be bad/dirty battery terminals?
skinned-knuckle is offline   Reply With Quote
Old 09-09-2022, 10:01 AM   #2
skinned-knuckle
Default Re: Flashing Warning Lights and Bouncing Gauges
two screenshots of video in case
https://drive.google.com/file/d/1yAQ...ew?usp=sharing
https://drive.google.com/file/d/1z0L...ew?usp=sharing
Old 09-09-2022, 10:36 AM   #3
skinned-knuckle
By the way, I am not a Saturn owner but I am comfortable with car DIYs
Old 09-09-2022, 12:43 PM   #4
In general, all Saturn instrument panel gauges and indicators are driven electronically by the body control module. The bcm essentially runs everything the engine computer (ecm/pcm) doesn't. The airbag and abs have their own computers. The bcm acting erratically may be a possibility but before concluding bcm failure, check main power; battery, battery cables and their connections including main grounds for corrosion/powdery buildup. Battery terminal corrosion is dried battery acid, neutralized with a solution of water and baking soda, toothbrushed on to dissolve this powder. Water rinse. Ions use a rear mounted battery so a long red positive cable runs from rear to front, terminating at the Remote Start post. This remote start post serves two purposes; provides a jumper cable connection for jump starting (negative connection to engine block) by the engine instead of from the trunk and distributes power to the main fuse panel and starter. Check this terminal for looseness. Battery grounds to chassis and another cable (insulated wire or insulated plain braid) from chassis to engine block. If these are ok then check alternator output.
Standby battery voltage should be around 12.5v while engine idling should show around 14.5v. Below 13v, suspect alternator, loose drive belt. A battery over 4 yrs old should be tested at any auto store selling car batteries.
Old 09-10-2022, 12:18 AM   #5
skinned-knuckle
@ fdryer: thanks so much for taking the time to post a reply. I'll check the potential problem areas you suggested and hope it resolves the issue. I'll follow up and post results.
Again, appreciate the help!
Old 09-10-2022, 03:21 PM   #6
skinned-knuckle
It worked. Made the trip and cleaned positive and negative terminals on battery, ground to chassis contact points and the positive post under the hood. Flashing warning lights and bouncing gauges stopped
Thanks again
Temp. Warning Flashing t_bell40 L-Series General 1 12-25-2011 10:32 AM
Flashing Warning Lights???? Epr7339 S-Series Tech 8 01-02-2008 04:11 PM
Electrical problem - NO gauges, warning lights, DRL, defogger sl2eggplant S-Series Tech 14 01-10-2007 04:22 PM
flashing dash warning lights kaseyskar S-Series Tech 1 08-25-2006 10:15 AM
help please! Flashing warning lights! jacob1200 L-Series Tech 4 02-27-2005 01:07 PM
