Old 02-16-2022, 01:55 PM   #1
ian_norris
ian_norris is on a distinguished road
Default Lowering Compression Ratio for Boost
Hi guys,
I have a 1995 Saturn SC2 DOHC and I am entertaining the idea of turbo-ing it. My primary concern is running 10+ pounds of boost in a 9.5/1 compression ratio engine. I have not been successful at finding pistons with dishes or lower compression height. Head spacers don't seem to be extreme enough. I'm trying to drop it to about 7.5/1, which- according to charts I've found online- should bring the active compression ratio to about 12/1, which should be ok on 98 octane gas (with the stock ignition timing?).
Does anyone know of a source for shorter/dished pistons for a '95 DOHC 1.9L? Alternatively, does anyone have other effective strategies for dropping compression ratio?
ian_norris is offline   Reply With Quote
Old 02-16-2022, 08:18 PM   #2
cgg17
cgg17's Avatar
1995 SW2
Default Re: Lowering Compression Ratio for Boost
Originally Posted by ian_norris View Post
Hi guys,
I have ran 7 psi on stock 1995 ignition timing with megasquirt for fueling.
Currently I run between 12-14 psi with megasquirt now controlling fuel and timing.
The engine has not been opened and has 195k miles on it. Have not had an issue yet, and I am running 93 octane pump gas.
What are your plans for tuning?
I will say this: if you do not plan on installing an aftermarket ecu for fuel and timing control, do not bother with a turbo.
1994 Sl2 5spd: First Car, Stock: 56,576 (Totaled 1/10/2018)
1994 Sl1 5spd: Inherited, Stock: 495,000
1995 Sl2 5spd: Retired Daily, Not Stock: 198,000
1995 Sw2 5spd: Daily, Stock: 110,000
Old 03-14-2022, 07:15 AM   #3
ultravioletnk
ultravioletnk will become famous soon enough
ultravioletnk's Avatar
2000 SC2
Hi guys,
the stock pistons for the 1st gen (1991-1995) sohc motors are dished, they've long been a popular choice for budget boosted builds. that said, the stock compression ratio is plenty fine for boost if you have good engine management and fuel. many cars these days are running turbos on 10:1 and higher, and direct injection engines push it even further.
rings-1996 sl2 ~215k mi
phoebe-1995 sl1 ~250k mi
janus-2000 sohc2 ~190k mi
tethys-1994 sw2 ~302k mi
rip mimas-wrecked 1996 sw1-trailer
pandora-1999 sc2
dione-1998 sw2
penny [iapetus]-1997 sw2
ultravioletnk is offline   Reply With Quote
compression ratio ad198592sl2 S-Series Mods 37 03-13-2011 01:14 AM
Compression ratio change? Monkius S-Series Mods 18 09-04-2006 05:14 PM
compression ratio slgirl Miscellaneous Tech 4 09-25-2000 01:40 PM
compression ratio Space-Boy '97SL2m Ion General 1 08-10-2000 02:57 PM
