![]() Join Date: Sep 2022
The car just recently got a new battery (for the 4th time). Now has a new alternator (2nd one so far), a new starter, a new master cylinder, and new bolts for connecting the cables into the battery. As well as a new air filter. And new spark plugs.
Just recently, for no obvious reason, the lights started going dim inside the car, then flickering, then the gauges started going haywire, the battery light was constantly flickering. The rpms went up but the car was barely getting up and going (basically like it was being pulled backwards while you are trying to go forward) shifting hard at times. The alternator is brand new, just replaced. The battery is brand new as well. We have new spark plugs and air filter... all the fluids are at the point they need to be... What is going on? We really don't want to sell it but we are stumped as its electrical or not? Bad ground? A short? Fuse? Relay? Sensor? Open to anything we can test and/or try at the very moment. We need every bit of advice possible!!!! |
You'll need a dc capable volt meter at the very least, that specific of a device is rare but digital multimeters are super common and cheap (example). If the alternator is working properly it'll give a steady voltage reading from 12.9v to 14.2v.
It's possible, with all the wire and part changes, a nut came loose somewhere. GM batteries are very picky about the torque on the battery terminal, about 11ft/lbs otherwise it either strips the battery threads or loosens on it's own. The large positive battery cable goes from the battery to the starter, then another wire (technically a "fuseable link") goes from the starter to the alternator. The smaller positive battery cable just goes straight to the fusebox next to the battery. The battery and fusebox terminals use a 8mm hex head, the rest are IIRC 13mm hex heads. You'll need ramps or jack & jackstands to check the alternator/starter ends of the cables, they're buried too much for most folks (including myself) to reach from above. Was the alternator actually new-new or reman-new? Do you know the build date of the SW2? '97 is an alternator change over year, Napa used to post the VIN on their site, with all the '97's I've had it was roughly a Dec-Jan build date. Up until the changeover they used the good alternator, same as the '91-'96's; after the change it's a smaller unit with a different harness plug. A lot of people have been very happy with DBElectrical alternators and starters, this new one is for the '91-'96 models: https://www.dbelectrical.com/product...400-12137.html A video on how to use the multimeter, it probably focus's on "around the house" checks but it's mostly the same for automotive: https://www.youtube.com/watch?v=ciyWwcKmPC4 |
Oh, it's and electrical problem; and sounds like it has been around in one form or another for quite a while. Hence throwing all the batteries and alternators at it. Are you doing the trouble-shooting personally, or taking it to a shop? If you are using a shop, you need to find a new shop. If it is DIY, then we need to help you learn better skills.
#4 | |
We have been seeking help from my dad (who is a mechanic. He is just thousands of miles away from me) We have been getting help here, advice from different shops. Mostly doing it solo because the car has a bunch of issues and we know a shop will withhold her. It has been wrecked before we bought it. 3rd owners or 4th owners for us. |
#5 |
I'll take that to mean you want to learn more about DIY. Do you have an electrical multimeter and know how to use it? What make/model is the meter?
Like your dad, will have to be using you as our hands and eyes. Following our directions and reporting back accurately will be crucial o our being able to help. Proof-read what you write before posting to prevent typos. Typos, or any other inaccurate info you post will cripple our attempts to help. Don't be discouraged, frustrated, or confused if some of us (including your dad) seem to be asking for redundant tests or seem to be heading you off in a completely different direction. All of us are acting in good faith, but there will often be different opinions on what is the best procedure or sequence for trouble-shooting. All tests, if results are reported correctly, are useful to some extent. Most can not hurt anything other than chew up a bit of your time. If one of us sees a post that does seem to involve some risk to the car or you, they will post a "dissenting opinion" or a caution on what the risks may be. |
#6 | |
I had a question. 1 problem is the rpms go up but the car is slow/wont accelerate much. Would that be something to do with a clutch/clutch plate? I'm literally chasing everything right now We have checked fuses, made replacements and triple checked every new part, new hook ups, every connection. We just got a new battery and once we hooked it up, it's already basically dead. Even got new cables for it. The alternator is new as well. Triple checked those connections as well. I grew up with my dad so I know a good chunk as well as learning more from people like you and him. Me and my partner just need this car to run and avoiding a shop is our current plan as those get expensive really fast. Also. I have been told to check the fuel filter and fuel pump |
1997 Saturn SW2 (HELP) | Vellyn | S-Series General | 2 | 09-15-2022 12:54 PM |
1997 Saturn SL2 - AC Oil ?? | gmcelroy | S-Series Tech | 5 | 09-18-2016 12:46 PM |
1997 saturn | lumpyyy | General Saturn Discussion | 1 | 05-18-2011 12:29 AM |
1997 Saturn SL2 | giger | S-Series General | 1 | 05-15-2006 10:24 PM |
Looking at 1997 Saturn SC2 | bromeoSC2 | S-Series General | 5 | 05-26-2005 03:14 PM |
