Old 03-24-2007, 12:08 AM   #1
Cathyztalkn2u
Cathyztalkn2u is on a distinguished road
Dizzy P0727 and P1780 error codes
I have a 2000 Saturn LS2 fully loaded...love it...did until the problems started. First the car would not start up on occasion. Seemed to be the security system. Then it would not start up after driving, shutting off and getting back in car...son changed spark plugs, am told now that i have a vaccum leak (thank you my son ). Have the manual, says engine speed sensor, ok...anyone have a clue as to where this thing is???? Evidently, there is a wire unplugged that needs to be plugged back in, unfortunately, we cannot find the sensor to plug that bugger into. HELP!
Add to Cathyztalkn2u's Reputation
Rate the quality of this post and help Cathyztalkn2u reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cathyztalkn2u is offline   Reply With Quote
Old 03-24-2007, 01:06 AM   #2
ksion15
ksion15 is on a distinguished road
2003 ION-1 Sedan
2005 RELAY-3
Default Re: P0727 and P1780 error codes
what code are you getting that tells you "engine speed sensor"? who says there's a vacuum leak? none of the codes you provided indicate either.
Add to ksion15's Reputation
Rate the quality of this post and help ksion15 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ksion15 is offline   Reply With Quote
Old 03-24-2007, 11:12 AM   #3
striker1211
striker1211 is on a distinguished road
2000 L-Series 3.0L Sedan
http://www.saturnfans.com/forums/sho...16#post1018816
I wonder if there was a emp (electro magnetic pluse) somewhere that blew out all of our CPS's (crankshaft position sensor) lol... or maybe cuz its getting warmer something is going on.
Add to striker1211's Reputation
Rate the quality of this post and help striker1211 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
striker1211 is offline   Reply With Quote
Old 03-24-2007, 10:07 PM   #4
lostwages_ls2
lostwages_ls2 is on a distinguished road
lostwages_ls2's Avatar
2000 Saturn LS2 V6-3.0L VIN R
Top - Vehicle
Technical Service Bulletins
. All Technical Service Bulletins
. . Engine - Intermittent Crank No Start/Multiple DTC's
Notes
BULLETIN NO: 00-T-28
ISSUE DATE: May, 2000
CATEGORY TYPE: Engine-10
CATEGORY: Starting/Charging
CORPORATION NO: 00-06-03-002
SUBJECT:
Intermittent Crank No Start with DTC P1780 Set in ECM History and/or U2105
Set in TCM or BCM History (Replace Main V6 Relay in Underhood Fuse Block [UHFB])
MODELS AFFECTED:
All 2000 L-Series Sedans and Wagons built before VIN YY630765 equipped with V6 (RPO L81) engines
CONDITION:
Some customers may comment the engine intermittently cranks but will not start and Service Engine Soon telltale is illuminated.
CAUSE:
The Main V6 Relay in the underhood fuse block (UHFB) intermittently may not function as designed.
CORRECTION:
Replace the Main V6 Relay using the following procedure.
PROCEDURE:
1. Disconnect negative battery cable.
2. Remove underhood fuse block (UHFB) cover.
3. Remove Main V6 Relay.
4. Install Main V6 Relay (P/N 12135170)
5. Install UHFB cover.
6. Connect negative battery cable.
Torque:
Battery Terminal Bolt: 17 N.m (13 ft-lbs)
PARTS REQUIREMENTS:
12135170 - Relay Asm-Acsry
CLAIM INFORMATION:
To receive credit for this repair during the warranty coverage period, submit a claim through the Saturn Dealer System for J6369 (Relay, ECM [Main V6] - Replace), or if another procedure is performed, refer to the appropriate Electronic Labor Time Guide for the correct labor operation code and time.
Disclaimer
Copyright 2007 ALLDATA LLC
Terms of Use
Your Honor Student is merely a pawn in my Min Pin's diabolical world domination plot.
Obey the Min Pin
Add to lostwages_ls2's Reputation
Rate the quality of this post and help lostwages_ls2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lostwages_ls2 is offline   Reply With Quote
Old 03-25-2007, 01:29 AM   #5
bspencer
bspencer is on a distinguished road
bspencer's Avatar
I thought that the V6 did not come with a manual trans? I could be wrong but that was the info that I have found.
EDIT:
The L200 does come with a manual trans but it is not a V6 so the TSB may not work for your car.
Add to bspencer's Reputation
Rate the quality of this post and help bspencer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bspencer is offline   Reply With Quote
saturn L300 trouble codes P0700 & P0727 kssbss L-Series Tech 14 07-10-2017 01:23 PM
P0727 & P1780 DTC's Cathyztalkn2u L-Series Tech 5 01-11-2017 06:33 AM
L-300 V6 codes P0727 and P0335 juanluk L-Series General 3 09-29-2009 09:51 AM
2000 ls v-6 codes p0727 p1780 p0181 juiced71 L-Series Tech 2 07-14-2009 06:45 AM
2003 L300 error codes P0700 & P0727 kssbss L-Series General 1 12-28-2008 08:29 PM
