Old 12-27-2008, 04:53 PM   #1
kssbss
kssbss is on a distinguished road
Default 2003 L300 error codes P0700 & P0727
I just pulled these codes off my code reader but cant find any info on them if anyone can help me I would appreciate it. the codes are P0700 & P0727 thank you very much
Add to kssbss's Reputation
Rate the quality of this post and help kssbss reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kssbss is offline   Reply With Quote
Old 12-28-2008, 08:29 PM   #2
lostwages_ls2
lostwages_ls2 is on a distinguished road
lostwages_ls2's Avatar
Default Re: 2003 L300 error codes P0700 & P0727
P0700 is a generic TCM error. See below
The Engine Control Module (ECM) , Transmission Control Module (TCM) , and the Body Control Module (BCM) communicate with each other over the Controller Area Network (CAN) bus circuits 2500 and 2501. The CAN BUS is a communications protocol that is used by the TCM to communicate vital engine control inputs from a stand-alone engine controller. The diagnostic checks the information received in CAN to determine whether a pass or fail code. Before checking the information, the TCM makes sure the CAN messages are being received by checking the BUS failure timer.
DTC PARAMETERS
DTC P0727 will set if:
CAN bus signal for the engine speed circuit is not responding for 2 seconds .
System voltage is between 8 and 18 volts .
Engine speed is greater than 500 rpm for 5 seconds and not at fuel cutoff.
DIAGNOSTIC AIDS
This code does not indicate a problem with the TCM. It does indicate the ECM is not sending engine speed to the TCM.
Determine the problem or look for trouble code(s) in the ECM.
Your Honor Student is merely a pawn in my Min Pin's diabolical world domination plot.
Obey the Min Pin
Add to lostwages_ls2's Reputation
Rate the quality of this post and help lostwages_ls2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lostwages_ls2 is offline   Reply With Quote
saturn L300 trouble codes P0700 & P0727 kssbss L-Series Tech 14 07-10-2017 01:23 PM
2003 Ion error codes long post pldaisy2 Ion Tech 5 02-18-2008 10:07 AM
P0727 and P1780 error codes Cathyztalkn2u L-Series Tech 4 03-25-2007 01:29 AM
Error codes P0133 & P0351 diddyk S-Series Tech 33 02-24-2007 10:50 PM
L300 Phantom Error Codes coachgeorge L-Series Tech 0 10-06-2005 11:46 PM
