Old 05-24-2007, 08:01 PM   #1
Cathyztalkn2u
Cathyztalkn2u is on a distinguished road
Attention P0727 & P1780 DTC's
Ok guys, I am desperate here! I own LS 2000 Saturn, ran fine...then one day would not start. Wait few hours, starts up. no more trouble for a year or so, now is happening on REGULAR basis. Runs when it wants to. Error codes show up as p0727 and p1780...ok, so engine speed input circuit, no signal...uhh, i cannot find a single thing about repairing this in my Saturn Repair Manual..waste of 20 bucks. Please, short of bleeding me dry...anyone out there have any suggestions???
Add to Cathyztalkn2u's Reputation
Rate the quality of this post and help Cathyztalkn2u reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cathyztalkn2u is offline   Reply With Quote
Old 05-24-2007, 09:13 PM   #2
Default Re: P0727 & P1780 DTC's
DTC P1780 Park/Neutral Position [PNP] Switch Circuit
DTC P0727 Engine Speed Circuit No Signal
1780; The neutral safety switch prevents starting in D, R, and L. Only in Park or Neutral but if the switch becomes misaligned over the years you won't be able to start in unless you push the shifter forward while turning the key to START. Same in Neutral. If a manual then the clutch safety switch may be misaligned.
0727; This one I think is the crank position sensor. Can the starter crank all day until the battery dies w/o the engine firing? The second test is to remove the coil wires from #1 and #4 and crank the engine while observing for sparks jumping across the coils; no sparks = defective crank position sensor. It's located behind and above the starter.
Old 05-24-2007, 10:36 PM   #3
CrewCab
CrewCab will become famous soon enough
CrewCab's Avatar
2008 AURA XE
1996 SL2
If you have a 3.0L V6, it is most likely a crankshaft position sensor going bad.
Add to CrewCab's Reputation
Rate the quality of this post and help CrewCab reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
CrewCab is offline   Reply With Quote
Old 05-26-2007, 04:12 AM   #4
Cathyztalkn2u
Yes I do have a 3.0L V6, is there any way of testing to be sure it is the crankshaft position sensor? Stupid car has been dead in driveway for about 9 days now. And yes I can crank it all day and it won't turn over!
Old 05-26-2007, 07:36 PM   #5
The easiest way to test the cps is to unplug it and read the resistance of the cps with a multimeter; the resistance should be from 800-1200 ohms. An open or no reading indicates a failed cps. Read this thread; http://www.saturnfans.com/forums/sho...d.php?t=100258 as it covers the cps test with wiring diagrams. Test the yellow and purple wire; an open or failure to read any resistance between the two wires indicates a failed crank position sensor; at $104 - rockauto.com is one place. The third wire is a shield going to ground. The other possibility is the cam position sensor so check the cps first as the cam position sensor can't be tested the same as the cps. The last resort is to tow the car to the Saturn shop for them to determine the fault with their Tech II scanner and they will find the fault quickly.
Because you didn't mention which engine I presumed you had the 2.2L and described the 4 cyl. spark test. The other poster checked his cps by removing one bank of his ignition module and layed it on the engine with plugs connected to test for sparks while cranking. That's a lot of work when its easier to read resistance from the two pins on the cps. Hope this helps.
Old 01-11-2017, 06:33 AM   #6
spectrum88
spectrum88 is on a distinguished road
2002 VUE 3.0L
my
my 2002 saturn vue awd v6 had that issue, but never came up with a cel code, it just simply ran untill it warmed up then cuts out, and i tried to start it, it wouldnt run untill it cool down. i tested this by usimg the ohm meter and water, since it was cutting out when warm. i had put the sensor in the water with the connector out of the water to test it, it should read some ohms, but when i warmed the water in the microwave and put the sensor back in and waited a minute, tested it and read nothing. bought a new one and ran great after that. this might help if no code is present.
Add to spectrum88's Reputation
Rate the quality of this post and help spectrum88 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spectrum88 is offline   Reply With Quote
saturn L300 trouble codes P0700 & P0727 kssbss L-Series Tech 14 07-10-2017 01:23 PM
2000 ls v-6 codes p0727 p1780 p0181 juiced71 L-Series Tech 2 07-14-2009 06:45 AM
2003 L300 error codes P0700 & P0727 kssbss L-Series General 1 12-28-2008 08:29 PM
P0727 and P1780 error codes Cathyztalkn2u L-Series Tech 4 03-25-2007 01:29 AM
DTC's Qman06 S-Series Tech 2 06-06-2006 07:29 PM
