Go Back   SaturnFans.com Forums > Reference Forums > Mods and Performance
Old 04-02-2003, 01:16 AM   #1
Sattyinsnow
Sattyinsnow is on a distinguished road
Dizzy Fog light install question
hey all
I was just want to bounce a few ideas off you guys for an install i wanna do i picked up a set of hallo blue's (crappy tire crystal blue fog lights) and i was wondering if instead of getting a switch to it. i want to attach them to my main lights so when their on the fogs go on and off and so forth.. but can i just splice and connect the power to the fogs and the low beams? also if i did that would the voltage or ampage, of each bulb change? like instead of a 100watts for 2 bulbs (50) and if i splise their only 25 watts to each light?? just wondering about this.
thanks for the help
Add to Sattyinsnow's Reputation
Rate the quality of this post and help Sattyinsnow reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sattyinsnow is offline
Old 04-02-2003, 01:34 AM   #2
Hiddenlites
Hiddenlites is on a distinguished road
Hiddenlites's Avatar
1993 SC2
Default
The limiting factors in your proposed setup are the fuses and the wires. Connecting the fog light to the low beam wiring will cause extra current to be drawn through the existing low beam wiring and fuses. This might cause the fuse to pop. If you use a larger fuse, you are risking too much current being carried by the low beam wiring which will create a fire hazzard.
So if you want to use your setup, you'll need to use larger guage wiring to supply the power to the low beams and fog lights.
1993 Saturn SC2 75k
2004 Chevy Silverado Z71
2008 Saturn VUE Redline 175k sold 7/8/16
2013 Honda Accord Coupe
2016 GMC Acadia
Add to Hiddenlites's Reputation
Rate the quality of this post and help Hiddenlites reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hiddenlites is offline
Old 04-02-2003, 02:13 AM   #3
Whelan
Whelan is on a distinguished road
Whelan's Avatar
Default
I had my fogs wired professionally. I have them setup so they go on with my parks and low beams, but I also have the auxillary shut off switch mounted in case I dont want them on. Works out well.
Add to Whelan's Reputation
Rate the quality of this post and help Whelan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Whelan is offline
Old 04-02-2003, 01:32 PM   #4
Sattyinsnow
Default
so they would draw more power and would heat up the wire and etc.. and fuses.. what if i wired them right to the end of low beams? (like where the low beams meet the controller or whatever it is to control them?? and just attach the fog wires to that instead of splicing it? would that work and i would just get a bigger fuse put in??
Old 04-02-2003, 01:46 PM   #5
wolfman
wolfman's Avatar
Default
Go to WALMART. Purchase a "Auxillary Fog/driving light wiring kit" (+/-$10) It will include the INSTRUCTIONS, wiring, switch and relay to do the job RIGHT. Wire the lights direct ANYWHERE in the "full power" side of the headlight circuit and you WILL overload the headlight circuit eventually.
Add to wolfman's Reputation
wolfman is offline
Old 04-03-2003, 05:07 PM   #6
WeeeZer14
WeeeZer14 is on a distinguished road
WeeeZer14's Avatar
2003 VUE 2.2L
2002 L-Series 2.2L Sedan
Default
Do as wolfman says... relays are your friend. If you hook the fogs up to the lows, you will probably get less light output than if you used the relay. And then there is of course the chance of blown fuses, melted wires, etc.
Add to WeeeZer14's Reputation
Rate the quality of this post and help WeeeZer14 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WeeeZer14 is offline
Old 04-04-2003, 12:37 PM   #7
Sattyinsnow
Default
hey wolfman what do you do anyways??? you seem to have the answer for almost anything saturn or well anything in general.. for that matter..
Old 04-04-2003, 03:35 PM   #8
mkosem
mkosem is on a distinguished road
Default
I'm prety sure wolfman was a Saturn Tech from 95-97 and is now a Police Officer.
--Matt
Add to mkosem's Reputation
Rate the quality of this post and help mkosem reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mkosem is offline
OEM Fog Light Install?? JavaPilot 2008 Vue 0 06-16-2009 05:16 PM
'96 Fog light install? Project84 S-Series General 8 12-17-2007 01:11 AM
06 vue fog light install question. autoxvw Vue Tech 6 07-05-2007 05:38 PM
How to Install Fog Light '97 SC2 venusfan S-Series Tech 2 04-06-2004 06:29 PM
Fog Light install Mongoose159 S-Series Tech 4 04-19-2002 08:04 PM
