Old 07-14-2011, 07:11 PM   #1
thecoachtony
thecoachtony is on a distinguished road
Default 1999 saturn sl
car will not idol or accelerate. have to feather gas to take off it eventually get to 25-30 mph. have changed fuel filter,it's getting gas. is it exhaust problem.can someone please help!!!!
Add to thecoachtony's Reputation
Rate the quality of this post and help thecoachtony reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
thecoachtony is offline   Reply With Quote
Old 07-14-2011, 08:06 PM   #2
Default Re: 1999 saturn sl
Easy way to check for exhaust obstruction is to remove the front O2 sensor. 7/8" or 22mm. If it runs fine with it out (other then being loud) then something (probably the catalytic converter...hope you don't live in CA) is clogged up in the exhaust.
Also, verify the ECTS has been changed using this guide: http://www.saturnfans.com/forums/showthread.php?t=37884
1999 Saturn SL2 need help UBean S-Series Tech 5 05-01-2011 04:08 PM
1999 Saturn SL2 UBean S-Series Tech 0 04-30-2011 02:55 PM
1999 saturn SL 2 barone S-Series Tech 19 09-30-2010 02:29 PM
Used 1999 Saturn SC2 cfg83 S-Series General 2 05-10-2010 05:07 PM
1999 saturn sc2 bluesharp1958 S-Series General 1 11-21-2009 01:43 PM
