Old 07-28-2009, 10:28 AM   #1
C130Flyboy
C130Flyboy is on a distinguished road
Dizzy Can not fix P0741 - TCC Stuck Off
Old problem cannot get fixed - My 98 SL2 had a auto Trans installed in March (since the old trans was getting the reverse slam which went away after changing the Oil and Filter then came back and starting leaking due to a small hole caused by the slam) Once the replacement Trans was installed all was great - for awhile. After driving for a few weeks the service engine light came on. I had Auto Zone scan and Code P0741 came up. reading post's I've replaced the Eng Temp. Sensor and this did not help (it was the old plastic design and was cracked). Can anyone tell me what the sensor is that goes into the Transmission that looks like the same thing? I have not replaced this yet since I do not know if it is related. The car will not shift into overdrive so I'm not getting as good MPG as I could. Other than that the car runs smoothly. Another note is that there is a wire that comes from the Trans to what I think is the Pattern Select Switch. This is a single wire with one clip even though the connector had two clips - this was loose and I tighten it - what is this, could it be related to P0741?
The Print out for the P0741 which states "General Motors" list other possible Reasons why I have code P0741:
1. TCC Solenoid failure: [B]How do I check this?
2. Open or short circuit condition: [B]Can I check this and what do I check?
3. Blocked passage in transmission: [B]How do I check?
4. Check Trans range switch for proper operation: [B]How? What does this do?
If I need a TCC Solenoid, can I check this be swapping out any of the others since they are all the same? Is this a good idea?
I need to get my car emission tested in Wisconsin and think I will fail even though it's Transmission related not emission. I'm thinking of clearing the code and taking it in (driving real slow so the light does not come on). I hope this will work. I'm not sure if they can extend my test date.
Add to C130Flyboy's Reputation
Rate the quality of this post and help C130Flyboy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
C130Flyboy is offline   Reply With Quote
Old 07-28-2009, 11:38 AM   #2
s3nfo
s3nfo's Avatar
2001 L-Series 3.0L Wagon
Default Re: Can not fix P0741 - TCC Stuck Off
Wrong forum.
Jerry N
Groucho Marx
Add to s3nfo's Reputation
Old 07-31-2009, 09:04 PM   #3
drewtiss
drewtiss is on a distinguished road
Add to drewtiss's Reputation
Rate the quality of this post and help drewtiss reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
drewtiss is offline   Reply With Quote
P0741 TCC stuck shut dewisp02 S-Series Tech 14 10-15-2014 12:50 AM
Transmission Code P0741 Can not fix C130Flyboy S-Series General 60 09-10-2009 10:19 AM
HELP !! My car is throwing a TCC STUCK ON freakinout28 S-Series Tech 1 10-23-2008 11:46 AM
TCC solenoid stuck off DTC 741 breasonable S-Series Tech 3 08-10-2008 09:54 AM
No gears and TCC stuck rockwood S-Series Tech 6 02-08-2005 12:01 AM
