Old 10-12-2017, 07:28 PM   #1
5littlejoe5
5littlejoe5 is on a distinguished road
2000 SL1
Default Used transmission installed, but shift pattern is wrong.
this transmission is guaranteed, and I'm trying to decide whether I'll have to take it out and send it back, or fix it. It starts and runs smoothly shifting without any roughness right up into overdrive. But then within a mile or two it seems to go into neutral or free wheeling, and (usually) won't go back into gear unless I stop (or at least slow way down). Then I can continue to drive it, but it will not shift up. It seems stuck in first, or second (4000 RPM at 30 MPH). If I let it set for 10 minutes it will go through the same sequence - starting out and shifting just fine, but then freewheeling, and locking me back to that 30 MPH-4000 RPM limit.
No strange noises, and the shifts are smooth when it does shift. New transmission fluid, and spin-on filter.
I thought that the shift solenoids might be at fault. Checked them, and all five seemed low resistance (less than 4 ohms). I've been struggling with this for awhile, so I had a set of them that checked out at about 5.1 ohms, and swapped them out, but it didn't seem to change anything.
Looks like it takes a major tear-down to change the internal filter. could that be the problem? or is their likely to be a better or simpler solution? It's a cute car with new tires, and upholstery But I'm spending way to much time and money on it.
5littlejoe5 is offline   Reply With Quote
Old 10-12-2017, 09:22 PM   #2
Default Re: Used transmission installed, but shift pattern is wrong.
Just out of curiosity, did you only use Dexron III compatible transmission fluid or something else in it?
Our cars cannot and must not use Dex IV or VI....ONLY Dex III.
Also, was the trans you got, from a SOHC or a DOHC saturn?
Old 10-14-2017, 07:04 AM   #3
5littlejoe5
2000 SL1
I don't know. I had the work done, and don't know which ATF was used. Just that it is new, and the filter is new. I was not aware of the requirement for Dexron III. I'll try to find out. Thanks for the suggestion.
The car (and the transmission) are SOHC
Old 10-14-2017, 09:13 AM   #4
Are you sure it's a MP6 transmission?
Are you sure it's a '98ish-'02 MP6?
ID guide attached (same location & scheme for the 5spds they're just MP2/MP3 for SOHC/DOHC).
I had a '00 Subaru Legacy Outback that needed a rear subframe...the idiot NC yard I picked sent me not one but TWO front sub-frames before telling me I didn't know what I was talking about. Oh well, the fronts rust out nearly as quickly as the rear's up here...got my money back and then some
Old 10-15-2017, 04:37 PM   #5
5littlejoe5
2000 SL1
[QUOTE=fetchitfido;2256928]Are you sure it's a MP6 transmission?
I don't find any similar number in that location, but the transmission fit's perfectly, and all of the connectors come out right. Mine is a 2000 SL1 SOHC , and the salvage yard where I got it said that it was compatible with 2001 ND 2002. Common opinion is that it should fit between 2008, and 2002. Aren't the MP2 and MP3 transmissions standard shift? I might be glad to chang it over to standard, but it looks like that would be a rather major undertaking.
Old 10-15-2017, 06:22 PM   #6
They will all "fit perfectly", they just won't shift perfectly if not the correct type. Look again for the ID number. They are hard to find or read, but it is a waste of everybody's time to try resolving this, your included, if it is the wrong trans. That characters in that number are a "dot matrix", will look like tiny pin-pricks in the metal. Again, very hard to see.
Old 10-15-2017, 04:26 PM   #7
5littlejoe5
2000 SL1
Yes The ATF that was used was Dexron III compatible according to the label on the container. And I was told that it would fit a 2001 or 2002 Saturn SL1. It bolted right in place, and all the connectors came out right. Mine is a SL1 year 2000, but my understanding from various sources is that it should be the same from '98-02
Old 11-13-2017, 01:33 PM   #8
I don't think this is related to your issue, but Dexron VI will say "Dexron III compatible" on the front . . . and in teeny, tiny print of the back, "except Saturn automatic transmissions" or something like that
subtle "rod knock" like sound, but the pattern is wrong cityhawk S-Series Tech 20 08-09-2016 09:31 PM
Is there a pattern to tighten the transmission panel? ( Side ) CaptainMouse64 S-Series Tech 1 12-17-2012 03:58 PM
New Pioneer radio installed, now a bunch of stuff is wrong! greekfreak Vue Tech 2 11-23-2009 05:36 PM
Shift Pattern on and XR gmsuv 2008 Vue 9 06-26-2008 06:44 AM
Has anyone installed aftermarket shift knob? johnsocal Ion General 9 12-18-2003 09:42 AM
