Old 05-26-2006, 04:57 PM   #1
Almost Wow
Almost Wow is on a distinguished road
Dizzy missing oil
i have a 2000 sl-1. in a 3000m oil intervel i will use 2q of oil. the car doesn't smoke or have any leaks. there's no oil in the coolent . i have been watching around the clutch for maybe a rear main. but i have no idea where it's going. the car also has i bit of a valve tap. i don't know any help is needed.
Add to Almost Wow's Reputation
Rate the quality of this post and help Almost Wow reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Almost Wow is offline   Reply With Quote
Old 05-26-2006, 05:10 PM   #2
Uzzy
Uzzy's Avatar
2002 SC1
Default Re: missing oil
It is burning it, but not in an excessive amount to see it out the tailpipe from the driver's seat. The Catalytic is eating up most of the blue smoke. Try an MMO soak or two, look up the procedure in the How-To section. 1qt is typical, 2qt is a bit excessive. The other option is to re-ring the pistons.
Aut viam inveniam aut faciam
Add to Uzzy's Reputation
Old 05-26-2006, 05:17 PM   #3
GreenSC2
GreenSC2 is on a distinguished road
GreenSC2's Avatar
OEM PCV valve is a good (cheap) starting point. If it is old and worn, it will contribute to sucking oil, if it is a cheap one from the parts store same thing.
It's not easy being Green(SC2). (IntelliTXT SUCKS)
I refuse to be a Lemming!!
Add to GreenSC2's Reputation
Rate the quality of this post and help GreenSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GreenSC2 is offline   Reply With Quote
Old 05-26-2006, 05:31 PM   #4
Almost Wow
thanx. that's what i was afraid of. it has a 107,000 on her. almost all highway. i'm guessing they have hydrolic lifters so they are probibly going bad but i will give it a try. i'm a diesel tech so this gas stuff is like chinese instructions to me. it's funny i can build a 800hp 1100ft/tq diesel pulling truck but a 100hp saturn hum i don't know. gas stuff well there's only one way to learn. thanks again for the help
Is something missing? MountaineerTom Ion General 2 09-02-2009 08:46 PM
Im I missing something here? alleninpa S-Series General 3 09-03-2007 09:51 PM
96 SC2 oil leak, cyl 3 missing Chucktin S-Series Tech 17 08-28-2006 03:23 PM
Missing.. need some help please! DarrylLeeOHS30 S-Series General 5 07-17-2006 07:59 AM
I must be missing something... Caprice General Saturn Discussion 25 02-16-2005 12:09 AM
