Old 02-18-2006, 09:22 PM   #1
donedds
donedds is on a distinguished road
donedds's Avatar
1996 SC1
Default Transmission filter vs Transaxle filter... are these 2 different things or the same?
The title says it all....
Thanks!
Add to donedds's Reputation
Rate the quality of this post and help donedds reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
donedds is offline   Reply With Quote
Old 02-18-2006, 09:36 PM   #2
DarrylLeeOHS30
DarrylLeeOHS30 is on a distinguished road
2001 SL2
Default Re: Transmission filter vs Transaxle filter... are these 2 different things or the same?
Yep. Transmission/Transaxle/Tranny... it's all the same!
-Darryl
Add to DarrylLeeOHS30's Reputation
Rate the quality of this post and help DarrylLeeOHS30 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DarrylLeeOHS30 is offline   Reply With Quote
Old 02-18-2006, 09:37 PM   #3
donedds
donedds's Avatar
1996 SC1
thanks... I was getting lost in some of the threads as they swap these terms around a lot...
Old 02-18-2006, 10:44 PM   #4
eRic 02sc2
eRic 02sc2's Avatar
A transaxle, in the automotive field, is a component that combines the functionality of the transmission, the differential and the drive axle into one integrated assembly. Front engine, rear wheel drive vehicles tend to have the transmission up front just after the engine, but sometimes a front engine drives a rear-mounted transaxle. typical automobile transmissions include the ability to select one of several different gear ratios.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 01-15-2010, 02:46 PM   #5
linushollis
linushollis is on a distinguished road
There is no service for the transaxle in the 2007 Greenline manual. How does one check the level or change the fluid & filter?
Add to linushollis's Reputation
Rate the quality of this post and help linushollis reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
linushollis is offline   Reply With Quote
Old 01-15-2010, 03:15 PM   #6
For an S-series with an automatic transmission, there is a red dipstick you can see at the front of the engine. As you look towards the engine, it is to the right of the yellow oil dipstick.
With a warmed up transmission, engine running, put selector in each gears with foot on brake, ending in Park. Pull out dipstick, wipe off, reinsert and pull out to look.
Drain and fill instructions are in the The How To Library
edit: I clicked the link above and found the How To for ATF changes <-- direct link
There's probably a richpin video, too
edit: Welcome to the forums It's very helpful to put your car information either in your post or in your profile. With automatic transmissions, the drain/fill procedure is the same for all S-series. For some other questions, the answer may depend on the year of car, engine type, etc.
Old 01-15-2010, 03:38 PM   #7
"Greenline" indicates one of several later "Saturn" models, but definitely not an S-Series car. Please post your question in the section relevant to your particular model (ION, Vue, etc.).
Add to madpogue's Reputation
Old 01-15-2010, 04:45 PM   #8
Ah, I thought "greenline" was some kind of generic automotive maintenance manual.
See, I'm still a Saturn newb
linushollis, you can see why posting your car information would be helpful...
Old 01-15-2010, 05:14 PM   #9
S3aturnR
S3aturnR's Avatar
1999 SL1
nope. a tranny is someone who dresses like the opposite sex...
s3aturnr
Add to S3aturnR's Reputation
cabin filter and inline transmission filter? mrtube Vue Tech 10 12-04-2009 08:38 PM
Transaxle filter and fluid change-I really need help! Chimmy S-Series Tech 7 11-01-2007 11:20 PM
Automatic Transaxle Fluid & Filter Change TXSaturn02 S-Series General 11 04-04-2007 04:31 PM
Oil change/filter & trans fluid /filter job completed ken b. S-Series General 2 06-03-2006 01:17 PM
Transaxle filter Laga Ion Tech 6 02-23-2006 12:01 PM
