Go Back   SaturnFans.com Forums > Categories > General Saturn Discussion
Old 04-16-2018, 07:07 PM   #1
daynewman
daynewman is on a distinguished road
2001 SL2
Default high beam headlight not working while running
My passenger side high beam headlight on my sc1 does not work with the engine running. If I turn the key to run and turn on the high beams both lights work but if I start the car the passenger side high beam goes out. the low beams work fine its just the high beams. I'm assuming it is a wiring issue but haven't been able to figure it out does anyone know what could be causing this?
Add to daynewman's Reputation
Rate the quality of this post and help daynewman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
daynewman is offline   Reply With Quote
Old 04-18-2018, 09:46 PM   #2
Sadmoto
Sadmoto is on a distinguished road
Default Re: high beam headlight not working while running
I had an issue similar when I replaced my headlights and globes except my daytime running lights stopped working but everything else worked fine, I ended up just unplugging the bulb and reseating it in there and whala it worked, it could be some as simple as it wasnt fully connected (I'm currently having that issue with my dashboard sadly the cable is lose so replugging didnt work for that like it did my daytime lights)
if not then look over the wires making sure nobody has nibbled on any wires because they are just so yummy!
Add to Sadmoto's Reputation
Rate the quality of this post and help Sadmoto reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sadmoto is offline   Reply With Quote
Old 05-15-2018, 06:22 AM   #3
Adellesigmund
Adellesigmund is on a distinguished road
great work
Add to Adellesigmund's Reputation
Rate the quality of this post and help Adellesigmund reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Adellesigmund is offline   Reply With Quote
Old 07-05-2018, 01:20 AM   #4
virtualking
virtualking is on a distinguished road
Check for the faulty connections of electric wiring , you should hire someone to fix it
Add to virtualking's Reputation
Rate the quality of this post and help virtualking reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
virtualking is offline   Reply With Quote
1995 SC2 high beam headlights not working aanderson0456 S-Series Tech 11 03-15-2016 05:21 PM
DRL's and Headlight High Beam Connection datlas S-Series General 15 12-19-2015 02:40 PM
No Power to Right High Beam Headlight! keautocenter S-Series Tech 3 08-26-2009 11:22 PM
96 SC2 High beam indicator problems and headlight adjustment gregaroo329 S-Series Tech 0 02-05-2008 12:44 AM
High beam switch not working KipDynamite Vue Tech 3 06-24-2006 08:25 AM
