Old 09-12-2012, 07:44 PM   #1
cola
cola is on a distinguished road
cola's Avatar
2009 AURA XE
1996 SL
Default Transmission Filter
Hi, I was wondering if replacing the transmission filter on a '09 XE with the 6-speed is recommended? Do I just drop the plan and remove the filter or is there more to it?
The car has 91k miles on it.
Thanks in advance,
David
2009 Aura XE 2.4-----SOLD
2004 Vue 3.5 AWD
1999 SL2 Auto
1998 SL2 5-Speed------SOLD
1996 SL1 5-Speed
Add to cola's Reputation
Rate the quality of this post and help cola reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cola is offline   Reply With Quote
Old 09-12-2012, 11:18 PM   #2
mbruneaux
mbruneaux is on a distinguished road
mbruneaux's Avatar
2007 AURA XR
Default Re: Transmission Filter
I called around and even a GM dealer and they don't list a filter for it......
On the Malibu forum a GM tech says there isn't a replaceable filter, drain and fill (6Qts) it is!
Add to mbruneaux's Reputation
Rate the quality of this post and help mbruneaux reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mbruneaux is offline   Reply With Quote
Old 09-13-2012, 07:36 AM   #3
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
i dont believe it has a filter
Add to onefunkar's Reputation
Old 09-13-2012, 02:23 PM   #4
greenman
2009 AURA XE
Thanks in advance,
David
GM suggest replacement only under severe service conditions. Personally, I would replace it at 100k. There's nothing unusual about this fluid & filter replacement. Make sure you also get a new filter seal & pan gasket (included with some filters). The filter is friction fit (i.e.-no fasteners).
The problem lies in getting the fluid level right as there's no dipstick.
Add to greenman's Reputation
Old 09-13-2012, 03:11 PM   #5
greenman
2009 AURA XE
Not sure if this link will work:
http://www.amazon.com/gp/part-finder...G8Y9FJDW1YRYYN
Old 09-13-2012, 03:24 PM   #6
cola
cola's Avatar
2009 AURA XE
1996 SL
Originally Posted by greenman View Post
Thanks for the info! I will order a new filter today.
2004 Vue 3.5 AWD
1999 SL2 Auto
1996 SL1 5-Speed
Old 09-13-2012, 05:03 PM   #7
greenman
2009 AURA XE
Forget what I said about changing the pan gasket. The OEM gasket is reuseable on these trannys & much better quality than the aftermarket versions.
Old 09-13-2012, 07:08 PM   #8
mbruneaux
mbruneaux's Avatar
2007 AURA XR
6 speed transmissions do not have serviceable filters....................
Old 09-13-2012, 10:42 PM   #9
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
pretty sure i dont have a filter to change and dipstick is on top of transmission.
Old 09-13-2012, 10:45 PM   #10
greenman
2009 AURA XE
Whoops. My bad. In the 6T40 & 6T70 series you have to drop the tranny to replace the filter.
Old 02-03-2013, 05:17 PM   #11
lugnuts
lugnuts is on a distinguished road
lugnuts's Avatar
2009 AURA XR
No user serviceable filter on the 6 speed. The guy above is right you have to drop the tranny. I just drain every 30k or so and replace aprox 4.5 quarts
Add to lugnuts's Reputation
Rate the quality of this post and help lugnuts reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lugnuts is offline   Reply With Quote
Old 02-03-2013, 10:15 PM   #12
davek128
davek128 is on a distinguished road
I took my 09 2.4L to an auto shop for a transmission flush at 40k. They hooked it up to a machine that replaces the fluid with the engine running. Shortly afterwards things started to go wrong with the car. 9 visits to the local chevy dealer within 3 weeks due to hesistation, car stalling, Service Traction, service ESC messages. They replaced 3 fuel injectors, the harness and I still had problems...Finally after having the car towed in, they found a broken wire. Well, I still had some hesitation and the trans was starting to slip. A co worker said the auto shop may have put in the wrong fluid. took the car back to the chevy dealer, paid $200 to have the trans flushed again. Bingo...no more hesitation, no more transmission slippage...
Add to davek128's Reputation
Rate the quality of this post and help davek128 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
davek128 is offline   Reply With Quote
Old 02-04-2013, 07:18 PM   #13
lugnuts
lugnuts's Avatar
2009 AURA XR
idiots. I've been shafted by shops before. PS fluid in master cylinder. That was fun. I bring my car into the shop as a last measure. If I can't figure it out.
92 SL1 Transmission Filter dgreen S-Series Tech 5 11-07-2010 09:26 AM
Transmission filter vs Transaxle filter... are these 2 different things or the same? donedds S-Series General 8 01-15-2010 04:14 PM
cabin filter and inline transmission filter? mrtube Vue Tech 10 12-04-2009 07:38 PM
Transmission Filter gunner3773 S-Series General 2 05-24-2009 08:16 AM
99 SL2 Transmission Filter MikeD2 L-Series General 3 10-30-2005 10:41 AM
