Old 12-24-2010, 08:56 AM   #1
TSC1969
TSC1969 is on a distinguished road
2008 Outlook XR
Default Anybody miss the Heated Washer Fluid Option?
For anyone that had the Heated Washer Fluid recall performed but wants to have that heater back, check out the link below:
http://www.alphathermusa.com/heatedwash-AT-37GM.html
Tim C.
2008 Outlook XR AWD
Silver Pearl - Black Leather
Advanced Audio w/DVD - Sunroof
Touring Pkg. - Chrome Running Boards
Trailering Pkg. - Convenience Pkg.
Enhanced Convenience Pkg.
Add to TSC1969's Reputation
Rate the quality of this post and help TSC1969 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TSC1969 is offline   Reply With Quote
Old 01-14-2011, 05:44 PM   #2
badtzbuzz
badtzbuzz is on a distinguished road
Default Re: Anybody miss the Heated Washer Fluid Option?
I miss mine, especially now in the North East. Has anyone installed one yet?
Add to badtzbuzz's Reputation
Rate the quality of this post and help badtzbuzz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
badtzbuzz is offline   Reply With Quote
Old 01-15-2011, 08:49 AM   #3
TSC1969
2008 Outlook XR
I installed it a couple of weeks ago and I am so happy to have it back. Works better than the original.
Tim C.
2008 Outlook XR AWD
Old 01-15-2011, 09:57 AM   #4
SC2BuzzBomb
SC2BuzzBomb is on a distinguished road
The original heated washer option was good at heating up the entire vehicle.
Add to SC2BuzzBomb's Reputation
Rate the quality of this post and help SC2BuzzBomb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SC2BuzzBomb is offline   Reply With Quote
Old 01-15-2011, 10:01 AM   #5
TSC1969
2008 Outlook XR
lol!!!
Originally Posted by sc2buzzbomb View Post
the original heated washer option was good at heating up the entire vehicle.
2008 Outlook XR AWD
Old 01-16-2011, 01:26 AM   #6
Harald
Harald is on a distinguished road
2007 Outlook XR
Five fires in 1.5million vehicles, according to the press release from last June...
Add to Harald's Reputation
Rate the quality of this post and help Harald reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Harald is offline   Reply With Quote
Old 01-19-2011, 01:20 PM   #7
electbc
electbc is on a distinguished road
Exactly what did the dealer do to perform the disabling of the factory system? I just ordered the aftermarket unit and want to install it myself.
Will the dealer install the aftermarket unit?
Will GM refund the cost of a aftermarket unit?
Add to electbc's Reputation
Rate the quality of this post and help electbc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
electbc is offline   Reply With Quote
Old 01-19-2011, 05:40 PM   #8
TSC1969
2008 Outlook XR
The dealer should have cut the wires on the fluid heater side of the plugs leaving the vehicle harness intact. They should have also removed the 60amp fuse for the unit. Follow the directions that come with the replacement unit and it's an easy install.
No, GM will not refund the cost of the replacement unit because they paid customers $100 when they removed the original.
Tim C.
2008 Outlook XR AWD
Old 01-20-2011, 10:20 AM   #9
electbc
If the dealer didn't perform the recall yet, will GM reimburse the cost of the aftermarket unit? I was scheduled to have the recall but I had to cancel the appt.Now I found the replacement unit and will install it. How can I apply for reimbursement and how can I contact GM to take me off the list of vehicles which were not updated with the correction?
Old 01-20-2011, 10:50 AM   #10
Harald
2007 Outlook XR
If it were me (and it was I'd have GM do the work because it's a factory recall for safety reasons. If your car ever catches fire you'll need to be able to prove to your insurance company that the recall item wasn't the cause of the fire, easier to do if you have paperwork saying they did the repair.
Old 01-20-2011, 05:15 PM   #11
TSC1969
2008 Outlook XR
I believe the GM dealer would be required to perform the recall if the vehicle was ever brought in to the dealer. They will not reimburse you for the replacement unit because it is not a GM approved unit. It would be best to let them perform the recall, but ask them to give you the fuse when they take it out. This way you will have it when you install the replacement unit.You will receive a check for $100 within a few weeks which will more than pay for the replacement unit. As far as the dealer installing the replacement unit, you should just ask them if they would be interested in doing it.
Tim C.
2008 Outlook XR AWD
Old 01-27-2011, 03:50 AM   #12
badtzbuzz
Installed the AlphaTherm unit this past weekend. It works great and I've been using it regularly in this Cold Freeze here in the North East.
Took about 30 minutes. It was a bit difficult to get at the factory wire harness', so I took off the intake, then removed the whole mounting bracket, removed the harness and followed the rest of the AlphaTherm instructions. I even used the factory hose clamps for a nice and clean install.
If you had the recall done, order the 60 amp fuse from Alpha, no need to go and get one.
Old 04-05-2011, 03:42 PM   #13
Harald
2007 Outlook XR
I'm about to take my truck in for the recall (finally!). Where is this 60 amp fuse - in the main fuse box, or somewhere in the wiring harness? (I seem to remember adding a fuse being the fix back during the first recall, which is why I ask - I'm hoping to remove the fuse in advance
Old 04-05-2011, 05:27 PM   #14
TSC1969
2008 Outlook XR
The 60A fuse is in the fuse box under the hood. I believe it's listed on the label that's under the lid of the fuse box.
The inline fuse that was added in the first recall will not be needed. The replacement unit won't require it.
Tim C.
2008 Outlook XR AWD
Old 04-06-2011, 10:01 AM   #15
Harald
2007 Outlook XR
Thanks, found it!
Old 04-22-2011, 08:08 PM   #16
electbc
Happy Re: Anybody miss the Heated Washer Fluid Option?
I also installed the aftermarket unit from alphatherm. It works but not as well as the original. When it heats up there is a few drops of washer fluid coming out the nozzles before the pump kicks in. Anyway, I am happy not to loose this feature.
Old 04-23-2011, 12:07 AM   #17
Harald
2007 Outlook XR
My GM one did that too - it's physics...
Old 06-25-2011, 09:19 AM   #18
electbc
Took the outlook into dealer for an airbag issue. Letter from GM said corrosion in a connector can cause Airbag Message to display. Dealer did work, covered by special policy.
I also gave him the old heated washer which I replaced with the Alphatherm unit, he recorded the recall as being performed. No connectors cut, or fuses pulled. Awaiting for the $100 from GM.
It is also nice to see the MADE IN USA label on the Alphatherm unit.
Old 07-24-2011, 10:40 AM   #19
tev9999
tev9999 is on a distinguished road
Is the unit located on the drivers side firewall, near the brake fluid fill port? I just noticed four disconnected black hoses in that location on my 2008 XR FWD. After my initial "who messed up my car" shock, I realized it was probably from the recall on the heated washer system.
Tempting to install for only $70.
Add to tev9999's Reputation
Rate the quality of this post and help tev9999 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tev9999 is offline   Reply With Quote
Old 08-04-2011, 12:41 AM   #20
Doug C
Doug C's Avatar
2008 Outlook XE
Devil Re: Anybody miss the Heated Washer Fluid Option?
Nope ! Glad I just have base unit this is just another example of extraneous (sp?) bling on new model cars that tend to break
Opposite situation . . . . at least some won't have to worry about finding/unloading the spare tire, in a few yrs with their next new car LOL
nite, doug c
Add to Doug C's Reputation
Rate the quality of this post and help Doug C reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturn Outlooks Recalled Due to Faulty Heated Windshield Washer Fluid System, GM to R Charlie Outlook General 11 06-14-2010 08:17 AM
What's the poop on heated washer fluid? logbite Outlook General 17 11-26-2008 09:44 PM
Heated Windshield washer fluid jpdiddy 2008 Vue 17 03-12-2008 02:47 AM
heated windshield washer fluid issue? Harald Outlook General 12 01-22-2008 07:54 PM
Heated Windshield Washer Fluid won't work Grazant 2008 Vue 5 11-08-2007 08:37 PM
