Old 07-05-2010, 04:39 PM   #1
LJ57
LJ57 is on a distinguished road
Default Transmission Filter
At this point I don't really want to go through draining the transmission fluid and replacing it, but I was thinking of putting a new filter on. Is this beneficial, or is it completely worthless if not draining/replacing the fluid?
2001 Saturn SL1
L4 - 1.9L vin 7 116ci - MFI GAS DOHC
100,000 miles
Add to LJ57's Reputation
Rate the quality of this post and help LJ57 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LJ57 is offline   Reply With Quote
Old 07-05-2010, 04:47 PM   #2
SLCraig
Default Re: Transmission Filter
I won't say entirely useless to do that, but I would replace both @ the same time.
Why not just use some inexpensive DexIII fluid and a new filter and call it a day?
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
Add to SLCraig's Reputation
Rate the quality of this post and help SLCraig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 07-05-2010, 04:52 PM   #3
mr18436572
mr18436572 is on a distinguished road
2000 SL2
+1
Especially seeing as how easy it is to drain and fill on these cars.
2000 SL2 auto - 167k - sold
1996 SL2 auto - 161k - sold
1997 SC2 auto - 105k - sold
2000 SC2 auto - 117k - sold
1996 SL2 auto - 250k - sold
2001 SC2 5sp - 160k - sold
Add to mr18436572's Reputation
Rate the quality of this post and help mr18436572 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mr18436572 is offline   Reply With Quote
Old 07-05-2010, 05:06 PM   #4
LJ57
I'm relatively new to working on my own car and before finding this forum, I had never tried to do anything myself. I did some searching, and it just seemed like draining the transmission fluid could be difficult and problematic. I guess I'm still trying to understand the difference between the drain and flush, though.
I wonder if richpin has a video for this? That might give me more conifence to give this a try.
2001 Saturn SL1
100,000 miles
Old 07-05-2010, 05:10 PM   #5
LJ57
If I go ahead and figure out how to drain the fluid, would a quart of cheap DexIII and a Wix filter suffice for this?
2001 Saturn SL1
100,000 miles
Old 07-05-2010, 05:14 PM   #6
mr18436572
2000 SL2
Drain and fill is just that. Very convenient and cheap, as you'll only need to buy a few quarts to top it off.
The flush involves the flush machine being hooked up to the transmission cooler lines, and letting the car run making the fluid circulate for several minutes until mostly new fluid is in the tranny. It costs about $80 and up at most shops. Downside is obviously the price. Not recommended by some (think the issue is possible dirt getting loose and clogging passages, creating transmission problems), but I've done it on almost all my cars without any problems, and would do it again when its needed and when I have access to the machine again.
Old 07-05-2010, 05:20 PM   #7
mr18436572
2000 SL2
You'll need 4.5 quarts for a drain and fill, according to one post
Old 07-05-2010, 06:25 PM   #8
LJ57
Thanks everybody! I'm going to give this a try.
I'm planning to go by the auto store and pick up one gallon of store-brand DexIII/M (Advanced Auto) fluid, a 7 qt. drain pan, and a 12 qt. recycle can. I think I have all the tools I need here. Is there anything else I will need? Thanks again!
2001 Saturn SL1
100,000 miles
Old 07-05-2010, 06:26 PM   #9
LJ57
And I have a Wix filter I'm going to use.
2001 Saturn SL1
100,000 miles
Old 07-05-2010, 06:29 PM   #10
jhonky
jhonky is on a distinguished road
i actually just tried to change mine the other day. i just barely couldn't get the filter wrench on it from below, and i didn't have the tools the other day to take out the air filter box and resonator. if you can change the filter you'd be silly not to change the fluid as well, seeing as thats quite simple to do and getting the filter off is all the effort of this job
Add to jhonky's Reputation
Rate the quality of this post and help jhonky reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jhonky is offline   Reply With Quote
Old 07-06-2010, 10:11 AM   #11
Unless you have another car, I'd pick up a little extra ATF. People have reported varying amounts of ATF that comes out and needs to be replaced; I think I've seen reports of between 3.5 and 5.5 qts, with 4~4.5 being average for most.
If you can change your oil, you can do this One drain bolt at the lowest point of the transmission, and a spin off filter. I believe wolfman wrote a How To in the How To library
A lot easier than other transmissions, where you have to pull the transmission pan and let it drain out of a corner of the pan.
Old 07-06-2010, 02:36 PM   #12
adventureoflink
adventureoflink's Avatar
I personally used five quarts of ATF when I did my transaxle fluid change.
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 07-06-2010, 07:31 PM   #13
LJ57
I went to the store today to pick up a wix filter, but they didn't have any in-stock. The guy there told me I should buy the PowerTorque transmission kit because it came with the gasket and something else. Do I really need the items in the kit, or will a basic screw-on filter be sufficient?
2001 Saturn SL1
100,000 miles
Old 07-06-2010, 08:30 PM   #14
All you need is a good filter. Go to NAPA and buy the NAPA Gold filter. Its a WIX hiding in a NAPA box.
Transmission filter vs Transaxle filter... are these 2 different things or the same? donedds S-Series General 8 01-15-2010 05:14 PM
cabin filter and inline transmission filter? mrtube Vue Tech 10 12-04-2009 08:38 PM
OEM transmission filter 92SL1Mann S-Series Tech 1 07-19-2008 08:46 PM
Transmission Filter RangerRuss S-Series Tech 10 05-09-2006 10:31 PM
99 SL2 Transmission Filter MikeD2 S-Series General 5 10-23-2005 03:41 PM
