Old 04-19-2011, 03:54 PM   #1
MyOutlook
MyOutlook is on a distinguished road
2007 Outlook XR
Default Struts on 07 Outlook
I'm getting ready to replace my struts again for the 4th time in less than 2 years. has anybody else had this problem? Have had every other problem that has been posted about, but haven't read anything about the struts. Just curious if these struts are a manufacturing problem, or if I'm being had by the dealership.....ie...not putting in new ones. The dealership does not like to see me walk in the door. Man, love my outlook, but have NEVER had as many problems with any other cars I've owned combined!
Add to MyOutlook's Reputation
Rate the quality of this post and help MyOutlook reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MyOutlook is offline   Reply With Quote
Old 04-19-2011, 04:47 PM   #2
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
Default Re: Struts on 07 Outlook
what are the struts doing that make you or them think they are bad?
Add to onefunkar's Reputation
Old 04-19-2011, 06:01 PM   #3
MyOutlook
2007 Outlook XR
They are leaking.....as been the case when they were replaced previous times
Old 07-30-2011, 09:39 AM   #4
Shewy
Shewy is on a distinguished road
2007 Outlook XR
I just had my 07' into the shop as I have a whining sound along with what sounds like a coil bind. I am told it is the strut brgs and are not covered under my extended warranty. Has anyone had this problem?
Add to Shewy's Reputation
Rate the quality of this post and help Shewy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Shewy is offline   Reply With Quote
Old 07-30-2011, 11:25 AM   #5
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
factory extended warranty shoulod cover struts. aftermarket may not
Old 08-04-2011, 12:53 AM   #6
Doug C
Doug C's Avatar
2008 Outlook XE
Had a oil service 6k back, at Certigard and they mentioned as part of their report that right front strut was leaking The service mgr told me to try and get replaced under warranty.
Thinks GM warranty should cover but also said they would likely 'waffle' on it with some reason or other !!
nite,
doug c
Add to Doug C's Reputation
Old 10-22-2011, 12:57 AM   #7
Doug C
Doug C's Avatar
2008 Outlook XE
Happy Re: Struts on 07 Outlook
The dealership DID replace the RF strut (early july visit) on warranty, even though earlier while swapping out winter set of tires for summers I had cleaned off the oil residue off the strut.
Luckily there must have been enough negative action to the strut assembly they decided to swap out also included a wheel alignment etc.
Maybe 'cause I also mentioned a rubbing problem on the drivers side wheel on some rubber flashing at the bottom inside fender well which covers a suspension 'joint'. Hopefully it does not come back when i swap back to winter set again in the next wk.
nite,
doug c
Outlook/Acadia Review Roundup - a list of all Outlook and Acadia Reviews ffballid Outlook General 25 04-07-2007 10:41 AM
Struts CurtisMonks S-Series Tech 8 02-08-2007 05:33 PM
will the outlook in teaser brochure be "the Outlook" SaturngirlSc2 Outlook General 13 09-15-2006 04:19 PM
aftermarket struts by sprint (xs struts) s-series SL2sleeper S-Series Mods 3 08-19-2006 09:24 AM
tie rod & struts 94sc2boy Miscellaneous Tech 5 11-04-2003 05:53 PM
