Old 03-05-2006, 11:19 AM   #1
custom1
custom1 is on a distinguished road
Wrench tire size
what is the biggest 14 inch tire I could possibly fit on my saturn sl 1. I was thinking about a 205/70/14 on the rear and a 195/70/14 on the front. Because of a cheap budget Pep boys has 14 inch rims for 200.00 from proline
Stephen
Add to custom1's Reputation
Rate the quality of this post and help custom1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
custom1 is offline   Reply With Quote
Old 03-05-2006, 11:38 AM   #2
eRic 02sc2
eRic 02sc2's Avatar
Default Re: tire size
I would not recommend using a wider tire on the rear than the front of a front wheel drive car unless you want to make it understeer worse than it already does now. plus it would look goofy. also 195/70-14 and 205/70-14 are quite a bit taller than the OE 175/70-14 so you may have problems with clearance. you could go with a 185/65-14 instead and maintain speedometer accuracy.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 03-05-2006, 06:32 PM   #3
3danh
3danh is on a distinguished road
3danh's Avatar
Stephen
Discount Tire's website: www.tires.com has some really cool tire info in the INFO CENTER area. They have a TIRE CALCULATOR at: http://www.discounttire.com/dtcs/infoTireMath.dos
205/70/14 vs. Stock 185/70/14 has a 1.65" taller height (overall diameter). I would not go with anything higher than 0.60 inches taller than stock with stock springs. If it's lowered, limit it to stock height for an SL2 which has 195/65/15's or an overall height of 24.21 inches.
Also keep in mind that sizes do slightly vary from each manufacturer.
My 95 SL1 is lowered with Eibach springs (1.3") with 205/50/16 all around and will occasionally rub when I go over railroad tracks or large dips at speed.
“Remember no matter where you go, there you are!”
Check out my website: www.TrickedOutSaturn.com
Add to 3danh's Reputation
Rate the quality of this post and help 3danh reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
3danh is offline   Reply With Quote
Old 03-06-2006, 10:52 PM   #4
steve-o
steve-o is on a distinguished road
steve-o's Avatar
1996 SL
similar question:
i only "need" to get 35k miles out of 'em.
96sl, 167k miles.
should i go with the 'stock' 170/75/14 (~$180 from sears general tire)
or 185/75/14 (~$120 from sears guardsman III/TE)
or 185/70/14 (~$150 from sears guardsman III)
or let it all hang out and get some viper tires?? http://www.sears.com/sr/javasr/produ...00&tab=spe#tab
about 25k miles per year, mostly hiway. some city. mostly no-sno, some sno (but i also have a truck incase it snows too much)
Add to steve-o's Reputation
Rate the quality of this post and help steve-o reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
steve-o is offline   Reply With Quote
Old 03-07-2006, 11:23 AM   #5
Earl43P
Earl43P is on a distinguished road
If you are buying rims, why not get the 15" ones and use the same size tires as a SL2?
It'll be a lower profile sidewall and wider tread. The overall diameter stays the same so speedometer error is not a factor. You gain better handling, better selection of rims in 15", etc.
Add to Earl43P's Reputation
Rate the quality of this post and help Earl43P reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Earl43P is offline   Reply With Quote
Old 03-07-2006, 12:24 PM   #6
adhhaahok
adhhaahok is on a distinguished road
adhhaahok's Avatar
1993 SC2
first off you need to know what the different numbers on tires mean.
Example: 195/65/15
195 is how wide they are, in this case 195 millimeters.
65 is how tall they are, in this case 65% of how wide they are, so 126.75 millimeters (195, width of tire, times .65, 65% of width of tire).
15 is what size rim they will fit on.
for the most part people know what the first and last number mean, but not the middle number.
picking a tire will be based on these numbers. a wider tire will generally create better road surface, for better handling, but a taller tire. a tire too wide will not fit on all cars becuase they will rub the struts. not all 15 inch tires will fit on all 15 inch rims, either. the width of the tire may excede the maximum holding width of the rim, Example: you cannot put a tire with a size of 295/30/15 (11.61 inches wide, 3.48 inches tall, 15 inch rim fitting) on a stock saturn rim. stock saturn rims are 7" wide and cannot hold a tire 11.61 inches wide.
i have aftermarket wheels that are 17x7 (17 inch rims that are 7 inches wide) with 205/40/17 on them, but they can hold up to 225/any number/17 on them. so, on your saturn rims, i would stick with anything 205 or lower. they will fit fine on your car and give a better ride. best size for a stock saturn is 195/65/15, but you have 14's so i would say that anywhere between 185 and 195 will be quite sufficient. what you need to look at is the quality of the tire and your budget.
hope this helped you guys.
oh, and, messing with tire sizes in this range will have a VERY LITTLE and unnoticable difference, to no difference at all in the accuracy of your spedometer.
Conversion chart, if you want to do your own metric to standard conversions :
http://www.sciencemadesimple.net/length.php
If you baby your car, it will baby your wallet...If you abuse your car, it will abuse your wallet.
1993/1995 SC2. You decide. http://www.cardomain.com/ride/2234915
Add to adhhaahok's Reputation
Rate the quality of this post and help adhhaahok reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
adhhaahok is offline   Reply With Quote
Old 03-07-2006, 08:54 PM   #7
RFDEV
RFDEV is on a distinguished road
1999 SL1
Here is a handy Tire Size Calculator
Add to RFDEV's Reputation
Rate the quality of this post and help RFDEV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RFDEV is offline   Reply With Quote
Tire Size D C Vue General 23 08-01-2007 11:37 AM
17" Konig Unknown, size? tire size? 92[SL2] S-Series Tech 1 05-14-2007 11:45 PM
tire size adan976g Vue Tech 8 05-01-2006 05:08 PM
Tire size SoUp S-Series Tech 4 09-07-2002 09:31 AM
Tire size Raiderdean S-Series Tech 2 02-25-2001 04:08 AM
